Originally posted by mrhappy
View Post
IKEA Tradfri and HomeSeer -> TrådfriSeer!
I'm getting an error every couple of seconds in my HS log to do with a bulb and wondering if you have an idea what may be up?
The error is;
GetColor() ERROR: Object reference not set to an instance of an object. --- {"9001":"Dining Table","9002":1504900111,"9003":65536,"9020":1506975022,"575 0":2,"9054":0,"9019":1,"3311":[{"5850":1,"5851":25,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217"}}
I can control it from HS just fine (and the colours do work) however the device returns to value 0 when it gets this error (I get a very brief change of value but when the error/the bulb is polled) the value is set back to 0.
The app reports the device works just fine, I am at a bit of a loss. I've tried having a look through a couple of documents about the data structures but 10:30PM is not conducive to concentration.
Possible firmware change on the bulb? Although I do have two other bulbs reporting version 1.2.217 and they seem to behave themselves.
Just looking a bit further in this...I've managed to find out relevant parts of the data structure and I don't appear to have the colour reply in the data (?) from what I can see I get 9003 (instance ID) in the main lighting structure along with the dim level and state of the lamp (makes me think that the colour would be in here). It appears that 5709/5710 should be present to pass the colour detail? It definitely is a colour temperature bulb and controlling it by the remote control works.
Originally posted by IanIreland View PostI only have one colour bulb - I bought it to 'play' with. I have no errors and can change colour via HS.
You would think deleting the bulb in HS would sort it if it was a plugin issue which makes me think that the data coming back from the gateway is wrong but can't see why it would only play up with one bulb?
Originally posted by mrhappy View PostPerhaps I should've been a bit clearer my fault...the RGB bulb I have works just fine. This is a standard warm/cool/normal white bulb that is playing up - it is strange because it is only one bulb that is doing this and the others I have work just fine.
You would think deleting the bulb in HS would sort it if it was a plugin issue which makes me think that the data coming back from the gateway is wrong but can't see why it would only play up with one bulb?Originally posted by ChrisH View PostDoes the current version 0.0.1.2 have an expiration date on it? I tried one of the first betas and that was working well. If there is no expiration then I will get it installed onto my production server. Thanks for providing it!
I'll read up on what I need to to in order to get this in the Updater before it expires.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by mrhappy View PostYeah controlling from the app works just fine in terms of warm/normal/cool, I am extremely confused with it (it is still giving me the error) and to me I just wonder is it confused that it thinks it is a RGB bulb but it isn't?
Originally posted by mrhappy View PostAlso one other minor bug appears that if I restart the plugin and have moved the Tradfri hub device (to another room possibly?) it creates a new device and uses this device for updates. Not a massive problem but thought I would mention it.
Can you post screenshots of from the "Advanced" tab for both devices?
Again, not that it would matter, but the IP stays the same, right?HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostThis seems really weird to me. If you enable debug logging and press the "Rescan bulbs" button it should display the config it receives for each bulb in JSON format. Can you post it?
No, you can change location and rename it to anything you want, it shouldn't matter to the plugin. As long as the key on the back of the hub is the same, it shouldn't matter. I'm using the key as an identifier.
Earlier when I restarted the plugin it appears that it scanned and got some groups from the hub that I had deleted from inside HS (I didn't need them, I'm guessing I should be keeping the HS devices regardless?) so it created the group devices. I've kept those devices but in addition it created this new Tradfri hub device.
I deleted the old hub device as I thought the new one replaced it but now I am wondering - is the IP and key stored in this device? Reason being I have restarted the plugin again and the IP/key have now gone. They are missing from the config page, ini file however the 'new' hub device does have the key stored in it (see attached).
On the first issue I have re-scanned the bulbs and this is the debug entries as per the HS log.
Oct-06 12:07:47 TradfriSeer Debug Gettin bulbs done!
Oct-06 12:07:47 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65548
Oct-06 12:07:47 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65537
Oct-06 12:07:46 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65541
Oct-06 12:07:46 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65542
Oct-06 12:07:45 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65536
Oct-06 12:07:45 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65544
Oct-06 12:07:44 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65539
Oct-06 12:07:44 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65540
Oct-06 12:07:43 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65546
Oct-06 12:07:43 TradfriSeer Debug Device found for bulb with key: 7O84ZSH7MkAqICbi, ID=65543
Oct-06 12:07:42 TradfriSeer Debug CheckAndCreateBulbDevices() starting...
Oct-06 12:07:42 TradfriSeer Debug GetBulbListWhenHubIsOnline() done!
Oct-06 12:07:42 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Total bulbs found: 10
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"TRADFRI wireless dimmer","9002":1506956738,"9003":65547,"9020":1507218283,"15 009":[{"9003":0}],"5750":0,"9054":0,"9019":0,"3":{"6":3,"0":"IKEA of Sweden","1":"TRADFRI wireless dimmer","2":"","3":"1.2.248","9":87}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Upstairs Hall Lamp","9002":1506706649,"9003":65548,"9020":1507286994,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":109,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 opal 1000lm","2":"","3":"1.2.214"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Desk Lamp","9002":1504898088,"9003":65537,"9020":1507281406,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0,"5708":0,"5707":0,"5709":30140 ,"5710":26909,"5711":0,"5706":"f1e0b5"}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E14 WS opal 400lm","2":"","3":"1.2.217"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Bulb 2","9002":1505038592,"9003":65541,"9020":1507286555,"5750":2 ,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Bulb 1","9002":1505038667,"9003":65542,"9020":1507287369,"5750":2 ,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Dining Table","9002":1504900111,"9003":65536,"9020":1507283492,"575 0":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Downstairs Hall Light","9002":1505145852,"9003":65544,"9020":1507283024,"575 0":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":51,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 opal 1000lm","2":"","3":"1.2.214"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Left Side","9002":1505147126,"9003":65539,"9020":1507282201,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":1,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E14 W op/ch 400lm","2":"","3":"1.2.214"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Right Side","9002":1505147152,"9003":65540,"9020":1507282163,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":1,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E14 W op/ch 400lm","2":"","3":"1.2.214"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"RGB Bulb","9002":1506113303,"9003":65546,"9020":1507282865,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0,"5708":0,"5707":0,"5709":38011 ,"5710":24904,"5711":0,"5706":"e78834"}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","3":"1.3.002"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Lounge Lamp","9002":1505145822,"9003":65543,"9020":1507288038,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":1,"5851":127,"9003":0,"5708":0,"5707":0,"5709":30140 ,"5710":26909,"5711":0,"5706":"f1e0b5"}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217"}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Remote control","9002":1506113234,"9003":65545,"9020":1506894190,"1 5009":[{"9003":0}],"5750":0,"9054":0,"9019":1,"3":{"6":3,"0":"IKEA of Sweden","1":"TRADFRI remote control","2":"","3":"1.2.214","9":87}}
Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"TRADFRI remote control","9002":1505147060,"9003":65538,"9020":1506873124,"1 5009":[{"9003":0}],"5750":0,"9054":0,"9019":1,"3":{"6":3,"0":"IKEA of Sweden","1":"TRADFRI remote control","2":"","3":"1.2.214","9":74}}
Oct-06 12:07:42 TradfriSeer Debug GetBulbListWhenHubIsOnline(): GetBulbs() queued...
Oct-06 12:07:42 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Hub is online, getting bulbs...
Oct-06 12:07:42 TradfriSeer Debug GetBulbListWhenHubIsOnline() starting...
Oct-06 12:07:42 TradfriSeer Debug GettingBulbsAsync() starting...Last edited by mrhappy; November 6, 2017, 12:26 PM.
Yes, the groups are re-created every time the plugin i started. I would suggest you just hide them if you don't use them, I'll see if I can add a "don't re-create groups" option.
The IP address is not stored in the hub device, only in the ini file. So far I'm not using the hub device for anything (except showing online or offline status) but I'm keeping the options open to support more than one hub.
It IS this bulb we are talking about?
Code:{"9001":"RGB Bulb","9002":1506113303,"9003":65546,"9020":1507282865,"5750 ":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0,"5708":0,"5707":0,"5709":38011 ,"5710":24904,"5711":0,"5706":"e78834"}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","3":"1.3.002"}}
Code:{"9001":"TRADFRI bulb E27 CWS opal 600lm","9002":1505920319,"9020":1507288330,"3311":[{"5850":0,"5851":254,"5707":0,"9003":0,"5708":0,"5709":42926,"5710":21299,"5711":0,"5706":"dc4b31"}],"9003":65543,"9054":0,"5750":2,"9019":1,"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","6":1,"3":"1.3.002"}}
This is weird!HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostYes, the groups are re-created every time the plugin i started. I would suggest you just hide them if you don't use them, I'll see if I can add a "don't re-create groups" option.
This is weird!
This is the suspect device (the RGB bulb works just fine);
Code:Oct-06 12:07:42 TradfriSeer Debug GetDeviceByID, got json-string: {"9001":"Dining Table","9002":1504900111,"9003":65536,"9020":1507283492,"575 0":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217"}}
Code:GetColor() ERROR: Object reference not set to an instance of an object. --- {"9001":"Dining Table","9002":1504900111,"9003":65536,"9020":1507290693,"5750":2,"9054":0,"9019":1,"3311":[{"5850":0,"5851":254,"9003":0}],"3":{"6":1,"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217"}}
Yeah, it IS very weird. Here's the command part of the JSON-string
Code:"3311":[{"5850":0,"5851":254,"9003":0}]
I would remove it and re-add it to the hub. I'm not sure, but I believe it will get the same ID as it had before, but do a bulb rescan anyways.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostYeah, it IS very weird. Here's the command part of the JSON-string
