I've looked through this board and have not found a solution to this problem.
I have a Sony XBR-55X850D TV. The Media Center Plugin works fine when the TV is powered on. I can power off the TV as well. However, after the TV has been off for a few minutes the according to the plugin it is offline and I can no longer power it on with the plugin. However the device is not offline. It still responds to http requests like http://192.168.0.158:55521/dd.xml. The only way to power it back on is with the physical remote control.
All settings for power savings, auto shut off, etc are OFF in the TV itself. It clearly is in standby mode as it responds the the dd.xml request.
Does anyone know how to fix this?
