Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > sirmeili Plug-Ins > MeiHarmonyHub (3P)
MeiHarmonyHub (3P) Discussion of MeiHarmonyHub plug-in
  #101
Old March 1st, 2018, 02:37 PM
DMT DMT is offline
Seer Plus
I am currently testing version 3.0.1.1 and it is working very well on my hubs.
I love the ability to set per device, per command repeats!!! Perfect for volume controls in HSTouch. Another nice touch is pulling in the harmony activity icons - I use status tracking in HSTouch.
I can't seem to be able to get the "On Activity Start" to stick on the main configuration page - when I refresh it always defaults back to "When Hub Updates Activity".
Also, when I updated the last 2 versions failed 3-4 times until I cleaned out the \Updates3 folder and put the MeiHarmonyHub .zip back in. Perhaps its just my particular system. Anyways, great plugin.
HS3 3.0.0.368 on Windows 10 Pro, HSTouch Designer 3.0.49
Plug-ins: BLLAN, BLUSBUIRT, Chromecast, EasyTrigger, Harmony Hub, Honeywell WiFi Thermostat, Insteon, MeiHarmonyHub, Z-Wave
  #102
Old March 1st, 2018, 02:54 PM
sirmeili sirmeili is offline
Super Seer
I will check into that On Activity Start. It defaults to "When Hub Updates Activity", so maybe I'm not pulling it back right.
Frank
  #103
Old March 1st, 2018, 08:22 PM
mterry63 mterry63 is offline
Updated to 3.0.1.1, seems to be working well.
  #104
Old March 2nd, 2018, 04:42 AM
frankis78 frankis78 is offline
i have latest 3.0.1.1 but it doesent seem to pull new activities.
I added a new activity to the hub, but i dont get it into the activity device
  #105
Old March 2nd, 2018, 08:04 AM
Super Seer
If you haven't restarted the plug-in, the default polling is set to 1 day so it can take some time to pick up. Otherwise if you restart the plug-in it should pick up new activities on startup.
Sent from my Pixel 2 XL using Tapatalk
Frank
  #106
Old March 2nd, 2018, 08:19 AM
I already changed the polling to 1 min, but didnt help, and now i restarted plugin, but still dont pick up the new activity
  #107
Old March 2nd, 2018, 08:25 AM
Super Seer
Ok. I'll check it out. It should really pick up on startup if nothing else. Have you done a sync with your hub (via the phone app or your remote)?
Frank
  #108
Old March 2nd, 2018, 08:43 AM
I used my phone to add the activity, and i also synced it with my phone.
I can use my phone to run that activity, so this shouldnt be the issue.
  #109
Old March 5th, 2018, 07:09 AM
Have you looked on the activity update?
I can control the devices that is already in homeseer , so i dont think communication is an issue. It just dont update new activities.
  #110
Old March 5th, 2018, 09:56 AM
Super Seer
Sorry, i was sick over the weekend and didn't get a chance to look into it. I will look tonight. I'm not sure why it wouldn't pick it up as it should, but I definitely don't doubt you. Chances are I'm missing something when requesting them.
Frank
  #111
Old March 5th, 2018, 12:33 PM
Ok great, let me know if i can assist in any way
  #112
Old March 5th, 2018, 05:04 PM
rprade's Avatar
rprade rprade is offline
OK. First issue so far. Running 3.0.1.0, I started getting these errors over the weekend and they are continuing today. The error is only for 1 hub, which seems to be working properly. The other two identical hubs are not generating the error.
Mar-05 1:53:26 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 1:53:26 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Mar-05 1:32:53 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 1:32:53 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Mar-05 1:29:36 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 1:29:36 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Mar-05 1:23:06 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 1:23:06 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Mar-05 1:08:32 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 1:08:32 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Mar-05 1:00:17 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 1:00:17 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Mar-05 12:54:16 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.129:5222
Mar-05 12:54:16 PM MeiHarmonyHub: Error The Conection to Hub with ID 31172a89-d5a3-4262-a62f-83e2360224a8 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect()
Randy Prade
Aurora, CO
Prades.net
  #113
Old March 5th, 2018, 09:44 PM
Super Seer
Ok, I just ran a test. I set my device polling at 1 min (for testing, I normally keep it at 1 day). I then opened up the MyHarmony program on my computer and added a new activity "Watch Roku 2". After that, I used my phone to sync the hub and during the next polling, the device was updated with the new activity.
So, this tells me that it "should" work, but it obviously isn't always working for some reason. Can you tell me:
How did you add the activity? did you use the My Harmony computer program or maybe your phone? <- Never mind, I see you said you used your phone. I'll try doing one that way.
What model Harmony Remote do you have?
Have you tried syncing again just to be sure (I'm sure you have)?
In the mean time I will look at the code a bit closer in case I'm missing something. I will also add some more debugging code around that and try and release a new version tonight.
Frank
  #114
Old March 5th, 2018, 09:46 PM
Super Seer
Thanks Randy. Some questions:
Is this hub the same model as the others? If not, what model is it?
Have you tried pressing the disconnect button?
Have you tried stopping and restarting the plugin?
I know the last isn't a solution, but I want to know if it's persistent between restarts.
Frank
  #115
Old March 5th, 2018, 09:51 PM
Super Seer
I was able to add it via my phone as well and get it to show up. I will add some more debugging.
Frank
  #116
Old March 5th, 2018, 10:49 PM
rprade's Avatar
All three hubs are the same model, purchased at the same time. I have restarted the hub twice, I have synced the hub and restarted HomeSeer. I disabled the hub on the config page.
Randy Prade
Aurora, CO
Prades.net
  #117
Old March 5th, 2018, 11:22 PM
Super Seer
Even with it disabled you still get the errors?
Frank
  #118
Old March 6th, 2018, 12:09 AM
rprade's Avatar
The errors continue after disabling the hub - until I restart HomeSeer. I could probably restart the plug-in. If I enable the hub again, there are no errors. The errors will start after HomeSeer is restarted.
Randy Prade
Aurora, CO
Prades.net
  #119
Old March 6th, 2018, 08:52 AM
Super Seer
Randy, I will do my best to try and reproduce using the information above. Not sure why it would be failing until a HS restart and then not again until a HS restart. I'll do my best to reproduce though and see if I can find a fix.
Frank
  #120
Old March 6th, 2018, 08:43 PM
rprade's Avatar
I might have been a little muddy in my explanation. The error occurs whenever the one hub is enabled. If I disable a hub on the configuration page, the errors continue until a restart. Likewise, if I enable a hub on the configuration page the errors do not begin again until a restart.
EDIT: It appears that this behavior is different with polling enabled. I had polling at the default (disabled). When polling is enabled the enabled/disabled status of the hub is updated at the polling interval.
EDIT 2: It also appears that the hub goes to "Forcefully Disconnnected" at the moment the error is logged, then it goes back to "Connnected". Note: the the misspelling of Connected and Disconnected is copied from the SV pairs in the hub device.
I have enabled debug logging and will send or attach a copy later. Where is the debug log stored?
Randy Prade
Aurora, CO
Prades.net
Jon00 Harmony Control jon00 Jon00's plugins and scripts 95 July 18th, 2018 01:31 PM
Description: MeiHarmonyHub (Logitech Harmony Hub Monitor and Control sirmeili MeiHarmonyHub (3P) 4 July 5th, 2018 10:44 PM
Feature Requests - MeiHarmonyHub (Logitech Harmony Hub Monitor and Control) sirmeili MeiHarmonyHub (3P) 10 April 12th, 2018 11:41 PM
Release Notes - MeiHarmonyHub (Logitech Harmony Hub Monitor and Control) sirmeili MeiHarmonyHub (3P) 0 February 15th, 2018 11:46 PM
Need a Harmony 900 Control HS3 Solution Sinandgrin HS3 / HS3PRO Discussion 4 March 19th, 2016 06:49 PM
