Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeSeer Wall Dimmers & Switches
HomeSeer Wall Dimmers & Switches Forum for HomeSeer Wall Dimmers & Switches
Old May 27th, 2018, 04:16 PM
mjgtp mjgtp is offline
HS-WD200 led indicator brightness
Is there a setting that can adjust the brightness of the LEDs when in status mode?
I just configured one dimmer to show me statuses of all the locks in the house, and it's actually fairly bright at night. The switch is facing away from me on the other side of a half wall, but even then, it lights up the side of a room in a green hue. Is there a way (setting) to dim down the LEDs a bit?
Tags
hs-wd200, leds
WD200+ LED Color smacarth HomeSeer Wall Dimmers & Switches 49 June 11th, 2018 11:35 AM
Help with HS-WD200+ jrjmpls7 HomeSeer General Discussion Area 4 June 10th, 2018 12:08 PM
WD200 Can I turn off the side LED after reaching desired brightness? Angry Virginian HomeSeer Wall Dimmers & Switches 1 May 31st, 2018 03:11 PM
WD200+ LED numbers missing ando1 HomeSeer Wall Dimmers & Switches 3 April 15th, 2018 02:50 PM
WD200+ Failures Sheriff HomeSeer Wall Dimmers & Switches 5 February 28th, 2018 11:42 PM
