Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeSeer Wall Dimmers & Switches
HomeSeer Wall Dimmers & Switches Forum for HomeSeer Wall Dimmers & Switches
Old May 29th, 2018, 08:45 PM
marcusone marcusone is offline
WD200+ dimmer speed settings
I found this about the WD100+ https://forums.homeseer.com/showthre...ht=ramp&page=2
but solutions there don't work for the WD200+.
I want to have the light come ON full Bright very fast when pressing the On (top) switch.
Yet if I set the zwave parameter to 0 for local, then I can not dim from the switch anymore!
Why is this still an issue with HS devices? I have a couple other brands that have different settings for ramping and hold down dimming speeds.
HS hopefully has added a new parmeter for "instant on/off" on when tapping the on/off button????
Anyone know a workaround for the WD200+ for now?
Marc
HomeSeer HS-WD200+ Dimmer for 240v users. Fellhahn Lighting & Primary Technology Discussion 16 June 10th, 2018 08:41 PM
WD200+ Dimmer - Last Level ???? PCK HomeSeer Wall Dimmers & Switches 5 May 24th, 2018 01:16 PM
WD200+ Dimmer Switch loops Mitch_Thompson HomeSeer Wall Dimmers & Switches 9 March 3rd, 2018 08:47 PM
Fan Speed Control with ZWave Dimmer switch mgluniewicz Lighting & Primary Technology Discussion 3 January 10th, 2011 09:47 PM
Fan speed control with Z Wave dimmer mgluniewicz HomeSeer Z-Wave Plug-in 2 December 23rd, 2010 01:09 PM
