Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeSeer Wall Dimmers & Switches
HomeSeer Wall Dimmers & Switches Forum for HomeSeer Wall Dimmers & Switches
Old May 31st, 2018, 03:07 PM
porterjj porterjj is offline
Viewer
Disable Dimming on WD200+?
Cliff Notes: Can paddle push and hold dimming up or down be disabled on the WD200?
I have installed a WD200 in a room that has Sylvaina Lightify recessed lighting. These lights are Zigbee controlled for anything beyond on/off, which is OK with me. I wanted the 7 LED lights for status mode of the WD200 verses the WS200.
I have found that my child (just now able to reach it) or unknowing guests always find a way to push and hold the paddle down putting the lights in to a disconnected state (flashing party mode as one guest called it) with the Zigbee hub. As a result I have to reconnect them, reconfigure any scenes I have setup in the Lightify App. I do have the HS Zigbee plugin running but the communication between HS -> Lightify -> Zigbee Hub -> lights is too slow for normal everyday on/off usage. I've already changed the on/off ramp rate to as instant as possible to avoid issues with just switch on/off function.
TIA
WD200+ LED Color smacarth HomeSeer Wall Dimmers & Switches 49 June 11th, 2018 11:35 AM
Help with HS-WD200+ jrjmpls7 HomeSeer General Discussion Area 4 June 10th, 2018 12:08 PM
WD200 LED status in HStouch ando1 HomeSeer Wall Dimmers & Switches 1 April 15th, 2018 06:32 PM
HS-WD200+ Dimming with HA-Bridge ando1 HomeSeer Wall Dimmers & Switches 4 April 7th, 2018 04:33 PM
WD200+ Failures Sheriff HomeSeer Wall Dimmers & Switches 5 February 28th, 2018 11:42 PM
