Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeSeer Wall Dimmers & Switches
HomeSeer Wall Dimmers & Switches Forum for HomeSeer Wall Dimmers & Switches
Old June 18th, 2018, 10:12 AM
jrjmpls7 jrjmpls7 is offline
Help with new HS-WX200
Came back from vacation and lights on switch don't work. Paddle operations ok.
When I trigger events I had set up lights don't react. Out of a couple of dozen tries to turn on a light it only worked once. And that one doesn't work when tried again. Anyone have any idea what may be wrong?
It was working when we left home 2 weeks ago and now none of the lights works.
Old June 18th, 2018, 10:32 AM
rprade's Avatar
rprade rprade is online now
It might have been stuck in a bad state from noise or power fluctuations on the line. Try power cycling it. If it is a dimmer, you can use the air gap switch on the device. If it is a switch, turn the breaker off for 30 seconds, then see if it starts working.
Randy Prade
Aurora, CO
Prades.net
Old June 18th, 2018, 11:35 AM
Pulled the air gap sw out and checked that the light didn't come on with the paddle. Pushed it back in so light works but indicators still don't do anything. Switch is barely a month old.
Old June 18th, 2018, 01:15 PM
Rupp's Avatar
Rupp Rupp is offline
Sounds like the switch has gone bad. I'd recommend putting in a help desk request at support@homeseer.com.
-Rupp
Old June 20th, 2018, 05:14 PM
Sent the switch back and then thought I should have removed it from the z-wave controller. Now that it's gone, how do I delete the node?
Thanx
Old June 20th, 2018, 05:53 PM
tome10's Avatar
tome10 tome10 is offline
Go to the root device>zwave>remove bad node. Then go into zwave controller>actions>import node info from controller to make sure it's gone.
Old June 20th, 2018, 06:28 PM
OK. Will do that. Thanx!!
Old June 28th, 2018, 08:55 PM
Please Help
Got back from vacation and nothing worked on switch except load control
Per previous messages I returned switch. Today I got new switch and it doesn't work either. It controls the load, and via HS3 I can control load. But multiple taps function and status lights do not work. These are all via events which worked at one time. Here is set up of one event:
Manually triggered, then":
Z-Wave Actions
HS-WX200 Actions
Device Z-Wave HomeSeer HS Wd200+ Dimmer
Set HS-WX2-- Action
Set Sstatus Mode LED Color
Led # 7
LED COlor Red
Blink Yes
What am I doing wrong? I had the previous switch working. What could I be doing wrong?
Thanx!!
Old June 29th, 2018, 10:07 AM
Got the multi-tap function working. But still can't get any status lights to go on.
Thought disabling and enabling status mode might help. When doing that get message saying
"Exception sending configuration data to HS-WD200+ Dimmer: Object reference nt set to an instance of an object."
But it still seems to change the staus mode properly. The lights are white and indicate dim status of load
when status mode is disabled. When enabled, the white lights only indicate load status when pressing the
switch. I think this is normal.
Please, can anyone see what I'm doing wrong? I can't believe one switch died after working and the replacement doesn't
work either. Just doesn't seem likely.
Old June 29th, 2018, 12:32 PM
Additional Info
Current Date/Time: 6/29/2018 11:30:48 AM
HomeSeer Version: HS3 Pro Edition 3.0.0.425
Operating System: Microsoft Windows 7 Home Premium - Work Station
System Uptime: 0 Days 11 Hours 55 Minutes 6 Seconds
IP Address: 192.168.1.101
Number of Devices: 157
Number of Events: 114
Available Threads: 400
HSTouch Enabled: True
Event Threads: 2
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
Enabled Plug-Ins
2.0.14.0: BLBackup
2.0.25.0: BLLAN
2.0.72.0: BLRF
1.0.3.0: BLShutdown
3.1.3.33206: Blue-Iris
3.0.0.40: EasyTrigger
3.0.0.27: EnvisaLinkAdemco
3.0.0.13: ImperiHome
3.0.6.23: Insteon
2.1.6.0: OpenSprinkler
3.0.0.83: weatherXML
3.0.1.190: Z-Wave
Old June 29th, 2018, 06:06 PM
I’ve discovered that, in the event, if I choose All instead of the HS-WD200+ device it seems o work. I guess I can use it this way as long as I don’t want to add any more swithes.
Can anyone help me get it to work correctly?
Thanx in advance!!!!!!1
HS3 Scripting docs/examples for WX200 actions? smuskiew73 HS3 / HS3PRO Discussion 0 April 14th, 2018 09:49 AM
RADI SHACK WX200 and WIRELESS ACCUWEATHER SUPPORT IN MSTEMP fbitz MCS Temperature 1 November 28th, 2003 08:55 PM
