I'm in the process of installing a single RC-80 thermostat to replace two individual thermostats (mercury style) which control a seperate heating and cooling system. My questions are;
1. Both systems are powered by different 24V supplies, would it be okay to use a single 24V supply for both systems?
2. Heating is done by baseboard while cooling is done via ducts. In heating mode, will the RC-80 also turn on the fan?
Does anybody else have their Thermostat connected to two different HVAC units? If so, can you explain how you did it
Thanks, Judd
Thanks, Judd
