Problem with output state.
    I am running the following script
    <php>
    Sub Main(ByVal parm As Object)
    Dim strResults As String = ""
    ' Turn output 011 On
    strResults = hs.plugin("UltraM1G").ControlOutput("011", "Off", "0")
    If strResults.Length > 0 Then
    Call hs.WriteLog("Error", strResults)
    End If
    ' Get output state
    Dim Output As Hashtable = hs.plugin("UltraM1G").GetOutputState("011")
    If Output Is Nothing Then
    ' Unable to get output state
    Else
    ' Do cool stuff with these results
    Dim strOutputName = Output("Name")
    Dim strOutputStatus = Output("Status")
    Dim strOutputLastChange = Output("LastChange")
    hs.WriteLog ("ULTRA TEST", "Name " & strOutputName & "-Status " & strOutputStatus & "-LastChange " & strOutputLastChange)
    End If
    End Sub
    </php>
    But I get the following error in my log.
    7/8/2008 1:55:48 AM Error Script compile error: Type 'Hashtable' is not defined.on line 24
    I had to change the "New Hashtable()" to "New System.Collections.Hashtable()" as follows:
    PHP Code:
    Dim Output As New System.Collections.Hashtable()
    Output hs.plugin("UltraM1G").GetOutputState("011"
    Updated script:
    PHP Code:
    Dim strResults As String ""
        End If
    Get output state
        Dim Output
    Output hs.plugin("UltraM1G").GetOutputState("011")
        If
        Else
            Dim strOutputName
    As String Output("Name")
    Dim strOutputStatus As String Output("Status")
    Dim strOutputLastChange As String Output("LastChange")
    hs.WriteLog("ULTRA TEST""Name " strOutputName "-Status " strOutputStatus "-LastChange " strOutputLastChange)
    End If
    End Sub
    Ultrajones
