Originally posted by SteveMSJ
View Post
Plugin to monitor Z-Wave battery device Health - CLOSED
Originally posted by bebaldin View PostThere is only one line - for the root device - that shows Waiting. No child devices representing battery devices have been created, and many of the battery sensors have woken up and updated in the last 8 hours.
Next go to your log and search for wakeup notifications. Put "Wake-Up Notification Received" without the quotation marks in the filter.
If there are wakeup notifications then set the LogLevel to 2 on the plugin configuration page and see what SDJ-health entries you get in the log after the next wakeup.
Steve
Originally posted by SteveMSJ View PostOK. Firstly make sure that wake-up calls are being logged:
Steve
Dec-28 14:56:37 SDJ-Health Checking status.
Dec-28 14:51:37 SDJ-Health Checking status.
Dec-28 14:46:37 SDJ-Health Checking status.
Dec-28 14:41:37 SDJ-Health Checking status.
Dec-28 14:36:37 SDJ-Health Checking status.
Dec-28 14:31:37 SDJ-Health Checking status.
Dec-28 14:26:37 SDJ-Health Checking status.
Dec-28 14:21:37 SDJ-Health Checking status.
Dec-28 14:16:37 SDJ-Health Checking status.
Dec-28 14:11:37 SDJ-Health Checking status.
Dec-28 14:06:37 SDJ-Health Checking status.
Dec-28 14:01:37 SDJ-Health Checking status.
Dec-28 13:56:37 SDJ-Health Checking status.
Dec-28 13:51:37 SDJ-Health Checking status.
Dec-28 13:46:37 SDJ-Health Checking status.
Dec-28 13:41:37 SDJ-Health Checking status.
Dec-28 13:36:37 SDJ-Health Checking status.
Dec-28 13:31:37 SDJ-Health Checking status.
Dec-28 13:26:37 SDJ-Health Checking status.
Dec-28 13:21:37 SDJ-Health Checking status.
Dec-28 13:17:23 SDJ-Health Saved report to /usr/local/HomeSeer/Temp/SDJ-Health Report.txt
Dec-28 13:16:37 SDJ-Health Checking status.
Dec-28 13:16:23 SDJ-Health LogLevel changed to 2
Originally posted by bebaldin View PostThe logs are full of wake-up notifications all day today (and before as well) including one just 3 minutes ago. I had LogLevel set to 2 already.
Dec-28 21:12:18 Z-Wave UZB1: Z-Wave Wake-Up 'No More Info' Notification sent to Node 88(Root Devices Node 88 Stella-2 Root).
Dec-28 21:12:18 SDJ-Health Root string updated.
Dec-28 21:12:18 SDJ-Health PEData written sucessfully to root device.
Dec-28 21:12:18 SDJ-Health Node 88 found in database
Dec-28 21:12:18 Z-Wave UZB1: Wake-Up Notification Processing for Node 88 (Root Devices Node 88 Stella-2 Root)
Dec-28 21:12:18 SDJ-Health Node 88 : Device Ref #782
Dec-28 21:12:18 Z-Wave UZB1: Z-Wave Wake-Up Notification Received for Node 88
Steve
Originally posted by SteveMSJ View PostOk. Can you post an extract from your log around a wake-up notification without any filtering. It should look something like this:
Steve
Dec-28 15:16:37 Z-Wave Home_North*: Device (Node 115) woke up and Poll Device for Sensor Living Room W Door: NW Entry was successfully sent.
Dec-28 15:16:37 Z-Wave Home_North*: Wake-Up Notification Processing for Node 115 (Node 115 Living Room W Door: NW Entry)
Dec-28 15:16:37 Z-Wave Home_North*: Z-Wave Wake-Up Notification Received for Node 115
That's it. There are no other entries about SDJ-Health around it.
Originally posted by bebaldin View PostDec-28 15:16:37 SDJ-Health Checking status.
I suggest you disable the plugin for now and I'll get back to you when I have some time to dig further.
Steve
Originally posted by SteveMSJ View PostThe plugin is not detecting the Wake-Up call for some reason. I will need to add a bit more debugging information to track down what is going on with your system. It might have something to do with the '*' character in the log entry.
Steve
Steve
Dec-28 15:46:33 SDJ-Health Node 9 - Ref #1490
Dec-28 15:46:33 SDJ-Health Node 26 - Ref #149
Dec-28 15:46:33 SDJ-Health Node 7 - Ref #1478
Dec-28 15:46:33 SDJ-Health Node 6 - Ref #1472
Dec-28 15:46:33 SDJ-Health Node 5 - Ref #1466
Dec-28 15:46:33 SDJ-Health Node 4 - Ref #1458
Dec-28 15:46:33 SDJ-Health Node 2 - Ref #1452
Dec-28 15:46:33 SDJ-Health Node 65 - Ref #1441
Dec-28 15:46:33 SDJ-Health Node 63 - Ref #1435
Dec-28 15:46:33 SDJ-Health Node 50 - Ref #1423
Dec-28 15:46:33 SDJ-Health Node 43 - Ref #1389
Dec-28 15:46:33 SDJ-Health Node 70 - Ref #1376
Dec-28 15:46:33 SDJ-Health Node 53 - Ref #1368
Dec-28 15:46:33 SDJ-Health Node 27 - Ref #1350
Dec-28 15:46:33 SDJ-Health Node 92 - Ref #1342
Dec-28 15:46:33 SDJ-Health Node 172 - Ref #1334
Dec-28 15:46:33 SDJ-Health Node 25 - Ref #1328
Dec-28 15:46:33 SDJ-Health Node 22 - Ref #1320
Dec-28 15:46:33 SDJ-Health Node 81 - Ref #1316
Dec-28 15:46:33 SDJ-Health Node 20 - Ref #1301
Dec-28 15:46:33 SDJ-Health Node 10 - Ref #1269
Dec-28 15:46:33 SDJ-Health Node 115 - Ref #1226
Dec-28 15:46:33 SDJ-Health Node 113 - Ref #1223
Dec-28 15:46:33 SDJ-Health Node 103 - Ref #1196
I had never seen this before. I will watch it for a while and see if it starts picking up devices now.
Steve
Mine is also behaving the same way. Single root device created at 7AM and marked "waiting". No child devices created or any update to the root device timestamp. Attached is an unfiltered log from my system. I figured the more info you have, the easier it may be for you to troubleshoot.
Originally posted by bebaldin View PostNo joy, unfortunately. Still no devices showing up. I will go ahead and disable until you can revise the logging.
Steve
[ATTACH]58421[/ATTACH]
Steve
Originally posted by Thickman View PostSteve,
I have a similar problem, I have two nodes 2 and 11, 11 shows up but 2 doesn't.
Steve
