API Mode and Floats
Can I as what Decimal mark you have set on your system?
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
I guess this is the problem. Can you test it by changing it to see if it helps. I will look at how to fix this.
Scripts = Various
Please try V1.0.0.138 from the updater and tell me if this helps.
Scripts = Various
Originally posted by enigmatheatre View PostPlease try V1.0.0.138 from the updater and tell me if this helps.
Greig.
Ok, with the latest sketch the device view shows the temperature like this:
With String:
14.25C
With Value& String:
14.25C
With Value:
1425
Is this the correct behaviour?
It also seems it is ignoring the localization ("," instead of ".")?
Will this create issues if I use this in events? for example comparing two values from different devices, one reporting with "," and one with "."?
Originally posted by doppiaemme View PostOk, with the latest sketch the device view shows the temperature like this:
With String:
14.25C
With Value& String:
14.25C
With Value:
1425
Scripts = Various
OK I have a different fix in place for this in v.139 in the beta updater. You only need to update the plugin and not the board sketch.
Scripts = Various
