I haven't opened my front door in several hours yet I open Homeseer on my Ubuntu machine and this is what I see in the console and it's not the first time. Most people have abandoned the homeseer version of this plugin for 3rd party plugins but I believe it was included with my pro license so fix it or release it to open source so I can fix it myself.
Homeseer version 3.0.0.445 has been running very well for me lately but every once in a while I will see a delay in my events that are triggered by me walking in the font door, DSC door contact is the trigger.
Experiencing that delay and seeing this kind of nonsense in the log makes me angry
I think I need a hug
underrun!!! (at least 362892607.723 ms long)
underrun!!! (at least 360337603.834 ms long)
underrun!!! (at least 372333344.600 ms long)
underrun!!! (at least 429800033.514 ms long)
underrun!!! (at least 430001839.412 ms long)
underrun!!! (at least 366353850.827 ms long)
underrun!!! (at least 366399290.330 ms long)
underrun!!! (at least 423668840.540 ms long)
underrun!!! (at least 366466453.442 ms long)
underrun!!! (at least 366928689.321 ms long)
underrun!!! (at least 67031638.477 ms long)
underrun!!! (at least 366966853.933 ms long)
underrun!!! (at least 360147193.152 ms long)
underrun!!! (at least 369373327.429 ms long)
underrun!!! (at least 369439728.378 ms long)
underrun!!! (at least 366556608.941 ms long)
underrun!!! (at least 366495262.707 ms long)
underrun!!! (at least 373017773.567 ms long)
underrun!!! (at least 423612464.219 ms long)
underrun!!! (at least 423722972.695 ms long)
underrun!!! (at least 367079339.814 ms long)
underrun!!! (at least 429950153.215 ms long)
underrun!!! (at least 366423536.335 ms long)
underrun!!! (at least 441148869.245 ms long)
underrun!!! (at least 438985552.782 ms long)
underrun!!! (at least 438942003.406 ms long)
underrun!!! (at least 439396394.693 ms long)
underrun!!! (at least 372974342.483 ms long)
underrun!!! (at least 366945440.712 ms long)
08:52:02:0343:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0365:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0366:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0378:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0385:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0389:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0393:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0397:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0415:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0417:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0418:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0420:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0424:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0427:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0428:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0429:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0437:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0439:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0449:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0467:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0484:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0496:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0513:[Event]->Event Automatic Front door opens, Action of HSTouch Actions could not be carried out because its configuration is not complete.
08:52:02:0514:[Event]->Event Automatic Front door opens, Action of HSTouch Actions could not be carried out because its configuration is not complete.
08:52:02:0516:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0515:[Event]->Event Automatic Front door opens, Action of HSTouch Actions could not be carried out because its configuration is not complete.
08:52:02:0523:[Event]->Event Automatic Front door opens, Action of HSTouch Actions could not be carried out because its configuration is not complete.
08:52:02:0535:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:02:0660:[Event]->Event Automatic Front door opens, Action of HSTouch Actions could not be carried out because its configuration is not complete.
08:52:02:0676:[Event]->Event Automatic Front door opens, Action of HSTouch Actions could not be carried out because its configuration is not complete.
08:52:02:9945:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0417:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0419:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0420:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0428:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0431:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0422:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0446:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0453:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0515:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0796:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0798:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0799:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0818:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0897:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0908:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0920:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0939:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0951:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0963:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
08:52:03:0976:[Event]->'Run Event' action execution skipped, the conditions applied were not met: Manually Triggered Front door opened in away mode
