How do you average temperature devices? This require a plugin? I have Jon00's Database Graphing PI, but i'm not sure it does averaging that I can use in an event.
Averaging Temperature Devices
Can be done easily in script. Plugin is not needed. You will create a third device which will be your average of the others. You will setup an event trigger for when the device value of any of the devices you are averaging changes. The action will be to run what can be a one line script so placed directly in the event action.
&hs.SetDeviceValueByRef(123) = (hs.DeviceValue(456)+hs.DeviceValue(789))/2
Where 123, 456, and 789 are the Device References of the three devices involved.
Note from the example code, hs.SetDeviceValueByRef has this form:
HS.SetDeviceValueByRef(Average, AverageTemp, True)
Why not use the same structure as in the example, and modify this line?
Dim AverageTemp = (BloomSkyTemp + CarParkTemp + GardenTemp + ShedTemp) / 4Mike____________________________________________________________ __________________
Originally posted by tome10 View PostI'm trying to use the code supplied by Michael McSharry. It is one line. Are you saying it was one line out of a larger piece of code? lol that would figure as I'm code illiterate.
looks like the 123 is the virtual device and 456 and 789 are the temp devices
Originally posted by tome10 View PostI agree, and that is the way I have it set up. I've never done this before, I don't know how the Virtual Device needs set up. I currently have on/off buttons, and it reads 100 for on, and 0 for off. So I think I need to create a device with just a textbox.
all you need to do is get the reference number for the virtual device set it in the script where the 123 is. maybe set the range of value in the virtual device to cover the range of temps. the script will set the value of the virtual device. are you getting an error in the log for the script?
Uncle Michael was correct about the format of the SetDeviceValue
&hs.SetDeviceValueByRef(1141,(hs.DeviceValue(1016)+hs.Device Value(1037)+hs.DeviceValue(1096))/3,true)
1141 is your new virtual device that was setup using DeviceManagent page of HS3. 1016, 1037 and 1096 are the three temperature devices. You will then use 1141 for charting or whatever you want to do with average temperature.
Here's my take on scripting average temperatures and a couple of screenshots showing the virtual device config that receives the calculated average.
Only the SourceDevices array and AvgTempDevice values should need changing for it to work on any HS3 system.
Code:Sub Main(Optional ByVal Parms As String = "") Dim SourceDevices() As Integer = {4789, 5098, 5760, 8290, 872} Dim AvgTempDevice As Integer = 1058 Dim AvgTemp As Double = 0 Dim DeviceCount As Integer = 0 For Each dvRef As Integer In SourceDevices If hs.DeviceExistsRef(dvRef) Then AvgTemp += (hs.DeviceValueEx(dvRef)) DeviceCount += 1 Else hs.WriteLog("AvgTempScript", "Error! Source device Ref:" & dvRef & " doesn't exist in HS.") End If Next If DeviceCount > 0 Then AvgTemp = AvgTemp / DeviceCount If hs.DeviceExistsRef(AvgTempDevice) Then hs.SetDeviceValueByRef(AvgTempDevice, AvgTemp, True) Else hs.WriteLog("AvgTempScript", "Error! Target device Ref:" & AvgTempDevice & " doesn't exist in HS.") End If Else hs.WriteLog("AvgTempScript", "Error! No devices to average.") End If End Sub
Though not the OP, thanks a million, Sooty... this worked great, with one very minor issue....
I don't seem to have the icon that you used. Should I?HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Enabled Plug-Ins
