Multi Channel Association
    I'm trying to figure out why multi channel association isn't functioning correctly on a Qubino dimmer that supports the multi channel association command class.
    Below is a screenshot showing the node information:
    My understanding is that a multichannel association device should present with an "endpoint" option when configuring association groups, I've seen examples of this in other threads:
    I also understand that on a multichannel association group node, association groups should be able to be configured from the endpoint itself, not just the root node.
    Neither of this is proving true for me, when I select an endpoint (switch in this case) and navigate to the z-wave tab, the associations section is greyed out.
    Also, when viewing the association group configuration on the z-wave tab of the root node, there is no "endpoint" option presented anywhere:
    Any tips on what I might be doing wrong?
    Is there an option I need to enable within HomeSeer to support multi channel association?
    Do I need to be using a particular interface? I'm currently using a HomeSeer Smart Stick+.
    We’re you able to find a resolution to this issue? I have come across the same one with Qubino modules.
      No, unresolved. I have 2 Qubino Flush dimmers and 1 Qubino 0-10v dimmer, both of these should allow me to capture the physical switch interactions via multi channel end points. But at this stage it's not working.
