I was setting up my HS3 system on a PI2 this weekend and ran into a problem with my Schedules Direct lineup not showing in BLTVGuide.
There is another post in this forum on this topic that says to remove an extra Newtonsoft.Json.dll from your HomeSeer root directory, but I didn't have one there.
I worked with Blade through his help desk over the weekend (thanks! ) and he uncovered the following error:
ERROR - Caught this web exception - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
Some quick Google research showed that this is related to Mono not having the correct SSL root certificates. I tried an 'apt-get dist-upgrade' and 'apt-get upgrade mono-complete' but that didn't help either.
The solution was running 'mozroots --import --ask-remove' which installed 140 root certificates.
So if you are running into this same problem, try updating your root certificates.
Hope this helps
Bob
Hope this helps
Bob
