Feature request: Message sending directly...
Hello George,
yes, that`s the perfect description of my wish !
Sorry, my english isn`t that good.
Maybe you can add also a box for selecting how long this message will show up on the soundbridge ?
Thanks a lot.
Another question:
I am on the way to buy one of those HomeTrollers.
Will your Plugin work on that also?
Eric
Hi Eric,
I've added the note about being able to specify all the message parameters when displaying from the control page.
I think the plug-ins should function in a Hometroller as long as it supports networking which I think it must. Let me know how you get on with it - I'm interested to know if it works.
George
Hi Eric,
The change you requested to display messages from the Roku control page is functionaly complete. I just need to tidy up the page layout, do some some more testing and make a release for submission to the updater.
Expect a new version sometime early next week. I'll keep you updated.
George
Good ideas,
Hi George
-Will you send similar messages every time?
> No I like your idea to make it possible to save some ( not all...) messages
-Would it be useful to be able to save the message and display settings as a preference?
> Yes, but not every one ! Maybe saving with a standard display setting as no other setting is chosen ?
-Or do you need a drop-down list of favorite messages?
> Is this not the same option as above ?
-Eric
Problem with version .17 on hometroller
George,
I just try to install and activate the plugin on my new HT.
Get this error message:
Server Error in '/' Application. <HR width="100%" color=silver SIZE=1>
Object variable or With block variable not set.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object variable or With block variable not set.
Source Error:
<TABLE width="100%" bgColor=#ffffcc><TBODY><TR><TD><CODE>An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</CODE> </TD></TR></TBODY></TABLE>
Stack Trace:
[NullReferenceException: Object variable or With block variable not set.] Microsoft.VisualBasic.CompilerServices.Container..ctor(Objec t Instance) +165 Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) +167 _RokuControl.Page_Load(Object sender, EventArgs e) +1342 System.Web.UI.Control.OnLoad(EventArgs e) +80 System.Web.UI.Control.LoadRecursive() +49 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3745
</PRE></CODE></TD></TR></TBODY></TABLE></P>
<HR width="100%" color=silver SIZE=1>Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42 <!-- [NullReferenceException]: Object variable or With block variable not set. at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ct or(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at _RokuControl.Page_Load(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)[HttpUnhandledException]: Exception of type 'System.Web.HttpUnhandledException' was thrown. at System.Web.UI.Page.HandleError(Exception e) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest() at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) at System.Web.UI.Page.ProcessRequest(HttpContext context) at ASP.rokuseer_rokucontrol_aspx.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.W eb.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)-->
