I am using AquaConnect from my PS4 wirelessly, and I wonder if it is causing my issue... Have the serial converter plugged into a Global Cache GC-100 that is plugged into a wi-fi router in bridge mode... which is connecting via a virtual com port on my server to communicate with HomeSeer. It seems that the Rx is working fine, as I am seeing the display update correctly, but button presses on the control window are not working, and programs are not controlling the pump schedule I have set up. Control ins intermittent, it does work fine at times, and others it does not.
From what I can tell, the logs show the transmissions as:
Monitoring the Tx and Rx in the virtual com port shows: https://imgur.com/fvFDGQz
Something potentially a weak point in the wireless set up, or something else? Would love some ideas. Please let me know if I can provide anything else.
Jun-25 6:32:44 PM AquaConnect ProcessResponse(10 02 04 20 20 41 69 72 20 54 65 6D 70 20 20 20 37 38 5F 46 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 07 7C 10 03 ) Jun-25 6:32:44 PM AquaConnect Entering RemoveSpecialChars(10 02 04 20 20 41 69 72 20 54 65 6D 70 20 20 20 37 38 5F 46 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 07 7C 10 03 ) Jun-25 6:32:44 PM AquaConnect Entering StripFrame(10 02 03 28 00 00 00 00 00 00 00 00 3D 10 03 ) Jun-25 6:32:44 PM AquaConnect Got LED update: 03 28 00 00 00 00 00 00 00 Jun-25 6:32:44 PM AquaConnect Entering RemoveSpecialChars(10 02 03 28 00 00 00 00 00 00 00 00 3D 10 03 ) Jun-25 6:32:44 PM AquaConnect Exiting RemoveSpecialChars(10 02 03 28 00 00 00 00 00 00 00 00 3D 10 03 ) Jun-25 6:32:44 PM AquaConnect ProcessResponse(10 02 03 28 00 00 00 00 00 00 00 00 3D 10 03 ) Jun-25 6:32:44 PM AquaConnect Transmiting: HSPI_AQUACONNECT.Util+TransmitQitem Jun-25 6:32:44 PM AquaConnect Transmiting: HSPI_AQUACONNECT.Util+TransmitQitem Jun-25 6:32:43 PM AquaConnect Exiting CreateChecksum(+) Jun-25 6:32:43 PM AquaConnect SendCMD sending : + Jun-25 6:32:43 PM AquaConnect Exiting SendCommand Jun-25 6:32:43 PM AquaConnect Entering CreateChecksum() Jun-25 6:32:43 PM AquaConnect Exiting CreateChecksum(+) Jun-25 6:32:43 PM AquaConnect Sending button release command + Jun-25 6:32:43 PM AquaConnect Entering CreateChecksum() Jun-25 6:32:43 PM AquaConnect Entering CreateChecksum() Jun-25 6:32:43 PM AquaConnect Exiting CreateChecksum(*) Jun-25 6:32:43 PM AquaConnect SendCMD sending : * Jun-25 6:32:43 PM AquaConnect Entering CreateChecksum() Jun-25 6:32:43 PM AquaConnect Exiting CreateChecksum(*) Jun-25 6:32:43 PM AquaConnect Sending button press command * Jun-25 6:32:43 PM AquaConnect Entering SendCommand for button Valve3 Jun-25 6:32:43 PM AquaConnect Transmiting: HSPI_AQUACONNECT.Util+TransmitQitem Jun-25 6:32:43 PM AquaConnect Transmiting: HSPI_AQUACONNECT.Util+TransmitQitem Jun-25 6:32:42 PM AquaConnect SendCMD sending : '; Jun-25 6:32:42 PM AquaConnect Exiting SendCommand Jun-25 6:32:42 PM AquaConnect Sending button release command '; Jun-25 6:32:42 PM AquaConnect Entering CreateChecksum(') Jun-25 6:32:42 PM AquaConnect Exiting CreateChecksum(;) Jun-25 6:32:42 PM AquaConnect Exiting CreateChecksum(:) Jun-25 6:32:42 PM AquaConnect SendCMD sending : ': Jun-25 6:32:42 PM AquaConnect Entering CreateChecksum(') Jun-25 6:32:42 PM AquaConnect Exiting CreateChecksum(;) Jun-25 6:32:42 PM AquaConnect Exiting CreateChecksum(:) Jun-25 6:32:42 PM AquaConnect Sending button press command ': Jun-25 6:32:42 PM AquaConnect Entering CreateChecksum(') Jun-25 6:32:42 PM AquaConnect Entering SendCommand for button Super Chlorinate Jun-25 6:32:42 PM AquaConnect Entering CreateChecksum(') Jun-25 6:32:42 PM AquaConnect Transmiting: HSPI_AQUACONNECT.Util+TransmitQitem Jun-25 6:32:42 PM AquaConnect Transmiting: HSPI_AQUACONNECT.Util+TransmitQitem Jun-25 6:32:42 PM AquaConnect SendCMD sending : '; Jun-25 6:32:42 PM AquaConnect Exiting SendCommand Jun-25 6:32:42 PM AquaConnect Exiting ProcessResponse(04 20 20 41 69 72 20 54 65 6D 70 20 20 20 37 38 5F 46 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 ) Jun-25 6:32:42 PM AquaConnect after removeing extra spaces = 20 41 69 72 20 54 65 6D 70 20 37 38 5F 46 20 Jun-25 6:32:42 PM AquaConnect Sending button release command '; Jun-25 6:32:42 PM AquaConnect Exiting FormatDisplayChars(20 41 69 72 20 54 65 6D 70 20 37 38 5F 46 20 ) Jun-25 6:32:42 PM AquaConnect Entering CreateChecksum(') Jun-25 6:32:42 PM AquaConnect Exiting CreateChecksum(;) Jun-25 6:32:42 PM AquaConnect Exiting RemoveSpecialChars(10 02 04 20 20 41 69 72 20 54 65 6D 70 20 20 20 37 38 5F 46 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 07 7C 10 03 ) Jun-25 6:32:42 PM AquaConnect Exiting CreateChecksum(:) Jun-25 6:32:42 PM AquaConnect Entering StripFrame(10 02 04 20 20 41 69 72 20 54 65 6D 70 20 20 20 37 38 5F 46 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 07 7C 10 03 ) Jun-25 6:32:42 PM AquaConnect SendCMD sending : ': Jun-25 6:32:42 PM AquaConnect ProcessResponse(): Got Display Update: 04 20 20 41 69 72 20 54 65 6D 70 20 20 20 37 38 5F 46 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00
