I noticed that it has been on since 12/9 shortly before 7pm. I received a low battery warning earlier that day. The following day I replaced the battery and also updated my Insteon plug-in to the latest version.
Any ideas what could have caused this or how to fix it?
What does this sensor actually detect? In other words, what exactly triggers it on and off?
Is it safe to try a factory reset on the motion sensor? I don't believe I've changed any of the default settings and I only have the 3 default links in it now:
Link #2 Dusk/Dawn Sensor has local control reporting to HomeSeer
Link #3 Low Battery Warning has local control reporting to HomeSeer
Link #1 Occupancy Sensor has local control reporting to HomeSeer
If after a reset I do a 'Program Device for HomeSeer' will it be reprogrammed with those links and be expected to function normally w/o any additional work?
Thanks for any input.
