Is there a way to enter security devices manually? Reason I am asking is that I am not using HS3 full time yet and in HS2 I am using ACRF2, if I add them to Rfxcom automatically they will change there code, making HS2 un functional.
Can you add security devices manually?
Originally posted by b_weijenberg View PostThe sensor defines the code. As long as you do not change the ID in the sensor there should not be a problem!
You can add the sensor in the RFXCOM HS3 plug-in and keep using HS2.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
