Spud,
I just noticed my NEST info is not working. I put the plugin in debug mode. I attempted to change the temperature through HS3 and you can see the error. Then I get a bunch of debug messages every 5 seconds. Let me know if there is any information I can provide. Thanks
Dec-02 10:21:29 PM Nest DEBUG Retrying in 5 seconds...
Dec-02 10:21:29 PM Nest DEBUG System.AggregateException: One or more errors occured ---> System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error). at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode () [0x00000] in :0 at FirebaseSharp.Request+d__2.MoveNext () [0x00000] in :0 --- End of inner exception stack trace --- at System.Threading.Tasks.Task.Wait (Int32 millisecondsTimeout, CancellationToken cancellationToken) [0x00000] in :0 at System.Threading.Tasks.Task.Wait () [0x00000] in :0 at System.Threading.Tasks.Task`1[FirebaseSharp.Response].get_Result () [0x00000] in :0 at FirebaseSharp.Firebase.GetStreaming (System.String path, FirebaseSharp.DataUpdatedEventHandler updated) [0x00000] in :0 at NestSharp.NestClient.StartMonitoringData () [0x00000] in :0 --> (Inner exception 0) System.Net.Http.HttpRequestException: Response status code does not indicate success: 500 (Internal Server Error). at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode () [0x00000] in :0 at FirebaseSharp.Request+d__2.MoveNext () [0x00000] in :0
Dec-02 10:21:29 PM Nest DEBUG response=StatusCode: 500, ReasonPhrase: 'Internal Server Error', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: { Date: Thu, 03 Dec 2015 03:21:29 GMT P3P: policyref="http://www.gap.com/w3c/p3p.xml", CP="ALL TAIa PUBa NOR" Server: Apache Connection: keep-alive Content-Length: 1 }
Dec-02 10:21:29 PM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.saVEXrKodT1tk4NgMmhs6OBvtG5rRcuXM31sXwTX00SJIW2 Cths0JZA7YYFHYTedzezAQ755oV1FA192MooPxI0eSf3LZ8xRY9TBRdPKGnn OPR6X34zVVkJqd3WeMoPEGboT5uzsD0NGGe5q', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
Dec-02 10:21:26 PM Nest DEBUG System.AggregateException: One or more errors occured ---> System.Net.Http.HttpRequestException: Response status code does not indicate success: 405 (Method Not Allowed). at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode () [0x00000] in :0 at FirebaseSharp.Request+d__16.MoveNext () [0x00000] in :0 --- End of inner exception stack trace --- at System.Threading.Tasks.Task.Wait (Int32 millisecondsTimeout, CancellationToken cancellationToken) [0x00000] in :0 at System.Threading.Tasks.Task.Wait () [0x00000] in :0 at System.Threading.Tasks.Task`1[System.String].get_Result () [0x00000] in :0 at FirebaseSharp.Firebase.Put (System.String path, System.String payload) [0x00000] in :0 at NestSharp.NestClient.SetTargetTemperature (System.String thermostatId, Double target, System.String scale) [0x00000] in :0 at HSPI_Nest.NestApp.ButtonPress (System.String buttonName, Double value, Int32 dvref) [0x00000] in :0 --> (Inner exception 0) System.Net.Http.HttpRequestException: Response status code does not indicate success: 405 (Method Not Allowed). at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode () [0x00000] in :0 at FirebaseSharp.Request+d__16.MoveNext () [0x00000] in :0
Dec-02 10:21:26 PM Nest ERROR One or more errors occured
Dec-02 10:21:26 PM Nest DEBUG PUT: path=devices/thermostats/SyE7pSBxL5P9ARo6N5_olA_VumSUMP-v payload={"target_temperature_f":71}
Dec-02 10:21:26 PM Device Control Device: First Floor Nest Target Temperature High to + (1001) by/from: CAPI Control Handler
Dec-02 10:21:24 PM Nest DEBUG Retrying in 5 seconds...
Current Date/Time: 12/2/2015 10:25:37 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.208
Linux version: Linux p-vubuhs301 3.13.0-44-generic #73-Ubuntu SMP Tue Dec 16 00:22:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 10 Days 2 Hours 8 Minutes 8 Seconds
IP Address: 192.168.1.40
Number of Devices: 122
Number of Events: 48
Enabled Plug-Ins
2.0.22.0: BLBackup
2.0.25.0: BLLAN
3.0.0.69: HSTouch Server
3.0.0.14: Nest
3.0.0.141: PHLocation
3.0.1.44: Z-Wave
Enabled Plug-Ins
2.0.22.0: BLBackup
2.0.25.0: BLLAN
3.0.0.14: Nest
3.0.1.44: Z-Wave
