I am able to control all of my devices with the Echo via the API. They have been working fine for the past several months. However, in the Alexa app, all of the devices say that they are offline. When I run discovery, nothing is discovered. When I remove a device and run discovery, the removed device is not rediscovered. I am on HS3 Linux version 280. I see that the available version is up to 293 now, but I have been reluctant to update it because last time I did, Echo control was lost. I had to drop back to 280 to restore it.
Should I just leave it alone as long as it is working? Should I worry about my devices being "offline"? Did something change on the Amazon end to make this happen? Should I try the update to 293?
Any thoughts or suggestions are welcome.
