Finally starting to use some new gifts from Santa. Received a number of Aeotec Smart Dimmer 6 (Gen 5) Everything is working except the Volts.
The log has:
Jan-19 20:43:01 Z-Wave Setting device Watts 1 to value 10.905
Jan-19 20:43:01 Z-Wave Set_New_Level, Parent: 3 Master Bedroom Aeon Labs Switch Multilevel, Child:3 Master Bedroom Watts 1
Jan-19 20:43:01 Z-Wave Set_New_Level_Real called for 3 Master Bedroom Watts 1, Type=COMMAND_CLASS_METER_V3, EndPoint=1
Jan-19 20:43:01 Z-Wave Set_New_Level_Real: Initial device is 3 Master Bedroom Watts 1
Jan-19 20:43:01 Z-Wave Device: 3 Master Bedroom Watts 1 Set to 10.905 (10.905 Watts)
Jan-19 20:43:01 Z-Wave ApplicationCommandHandler from node 7 HANDLING: COMMAND_CLASS_MULTI_CHANNEL_V3 Frame(7)=13
Jan-19 20:43:00 Z-Wave Setting device Amperes 1 to value 0.098
Jan-19 20:43:00 Z-Wave Set_New_Level, Parent: 3 Master Bedroom Aeon Labs Switch Multilevel, Child:3 Master Bedroom Amperes 1
Jan-19 20:43:00 Z-Wave Set_New_Level_Real called for 3 Master Bedroom Amperes 1, Type=COMMAND_CLASS_METER_V3, EndPoint=1
Jan-19 20:43:00 Z-Wave Set_New_Level_Real: Initial device is 3 Master Bedroom Amperes 1
Jan-19 20:43:00 Z-Wave Device: 3 Master Bedroom Amperes 1 Set to 0.098 (0.098 Amperes)
Jan-19 20:43:00 Z-Wave ApplicationCommandHandler from node 7 HANDLING: COMMAND_CLASS_MULTI_CHANNEL_V3 Frame(7)=13
and the device is:
Reference ID 1117
Technology Address F83F974B-007-Q28
Status 0 = OFF
Value 0 = "0 "
String
Supports Status True
Dimmable False
Interface Z-Wave
Extra Data Store 39 Named entries, 0 UnNamed entries.
Device Type Internal Energy API, Type: Volts, SubType:
Device Type (String)
Z-Wave Volts
So I'm not sure what the issue is. I have about 50 of their nano/micro smart switch and they all have Volts and they work.
Michael
The log has:
and the device is:
Reference ID 1117
Status 0 = OFF
Value 0 = "0 "
String
Dimmable False
Interface Z-Wave
Z-Wave Volts
Michael
