HI,
I've been using the Sonos plugin and the HS text to speech for a while with a specific SONOS Play1 speaker in my house without an issue. I use this mostly via vb scripts in events (see the exemple below)
Sub Main(ByVal parm as String)
hs.speak("test", True, "$SONOS$Cuisine$")
End Sub
This morning, I decided to expend my TTS messages through another SONOS Play1 and there was a huge 15-45 second delay before anything came out of the box so I went in the log file and saw this message:
Error in DoCheckAnnouncementQueue. 100 seconds expired since the announcement started and no end was received.
I tried many times the script and found out that the message was played only once the error was written in the log so I guess that when this message is issued, hs.speak release an "end" statement which then send the message.
I looked on the forum and only found references where the problem was with firewall wich for sure is not the case with my issue since the firt SONOS works perfectly.
Anybody would have an idea on the issue ?
HS3 Pro Edition 3.0.0.368 (Windows)
OS Version: 10.0.16299 Service Pack: 0.0
Sonos PI 3.1.0.16
End Sub
Sonos PI 3.1.0.16
