Michael,
Since adding a 3rd audrey to my setup, I am starting to see these error messages quite often with the slideshow.
Error: Connect Failure
Could not connect to the requested host.
Unable to access http://192.168.1.10:81/AudreySlideshow.asp.
I did not have this problem with only two audreys (or it happen so little that I never noticed it). I'm wondering if it is due to a speed issue on the HS server. I'm guessing that since I am using the default HS server, the AudreySlideshow.asp is creating the page to be pushed to the audrey, and now with 3 of them, am I getting overlaps where one audrey is requesting a slide and while the HS is generating the page, a 2nd audrey comes and asks for a slide and HS erases the first one before it gets served? Currently my HS box is only a Celeron 800 with 512 RAM running W2K Server. What can you suggest to help prevent this error message on the slideshows. I have a 4th audrey coming soon and this will only make things worse.
The Pod
The Pod
