Monitor GFCI trip
    Monitor GFCI trip
    So I lost my Hot Tub this winter when I didn't notice that the GFCI tripped and it froze. (It was on the list for a 1-wire temp monitor but hadn't been implemented yet).
    Now that I'm installing a new tub, I want to monitor the GFCI power and trigger an event if it trips. Is there a canned solution for monitoring a 240VAC breaker or do I have to create it from scratch? I'm hoping to power the alarm from a nearby 120VAC line to eliminate batteries.
    Anyone using the Jacuzzi Pro-Link app with HS (I'll drop this in the Pool Discussion)
    Jeff
    You could add a 240VAC contactor or solenoid to a low voltage switch and connect it to an alarm panel if you wanted to.
    A 1-wire USB stick and underwater probe would cost in the vicinity of less than $25. Using a wireless RPi3, a rechargeable battery and little solar panel you do go totally wireless with a solution. Old neighbor did all of his outdoor LV LED lighting with two 12VDC batteries and two small solar panels. Worked for years this way.
    I am currently building a small 1-wire temperature / humidity network for the second floor of the home using an RPi2 POE connected in the attic. Note that I have kept an RPi2 in the attic now for some 2 years and it hasn't melted yet. The old 1-wire network was using a star topology and cat5e down to the basement.
    Auto mator
