Originally posted by dcorsus
View Post
I will double chech intall run as admin. I went in to config and set debug and superdebug the turned PI on. Here is the log. The last device is one of my Diretv dvrs. Tomorrow I will try and unplug it.
The GUID that is in last few log entries shows up in the regestry once in a devive entry and onces a root entry for UNDRenders in the windows media plaers NSS section. I will study the entries and compare to others.
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~Application path: C:\Program Files\HomeSeer 2
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~Register callback completed
12/5/2012 11:43:58 PM ~!~Plug-In~!~Initializing Plug-in: DLNA_Manager
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~InitIO Called
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~InitializeUPnPDevices called
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~INIT: MaxNbrOfUPNPObjects set to 0
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~GetIniSection called with Section = UPnP Devices to discover
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~ReadIniFile has discovered 6 device types to look for
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~InitializeUPnPDevices Found Housecode in inifile. HouseCode = %
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~BuildUPnPHSDeviceInfoList called
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~DetectUPnPDevices called with Refresh = False
12/5/2012 11:43:58 PM ~!~DLNA Manager~!~FindUPnPDevice: Attempting to locate all connected. This may take up to 9 seconds.
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice - Discovery succeeded: 12 UPnPDevice(s) found.
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:MediaRenderer:1 with FriendlyName = DIRECTV Mediashare Renderer
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.195:49153/virtual/description.xml
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.195
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found IPPort = 49153
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a DIRECTV device with UDN = 29bbe0e1-1a6e-47f6-8f8d-0019dfba026f and Friendly Name = DIRECTV Mediashare Renderer and adding it to the array with index = 0
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' isRoot = True
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' Description = DIRECTV Plus HD DVR
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' ModelNumber = 1.0
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' hasChildren = False
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' ManufacturerURL = http://www.directv.com/
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' ModelName = MediaRenderer
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:MediaServer:1 with FriendlyName = DIRECTV2PC Media Server
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.197:49152/virtual/description.xml
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.197
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found IPPort = 49152
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a DIRECTV device with UDN = DIRECTV2PC-Media-Server1_0-RID-035697224430 and Friendly Name = DIRECTV2PC Media Server and adding it to the array with index = 1
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' Description = DIRECTV2PC Media Server 1.0
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~' ModelName = MediaServer
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.196:49153/virtual/description.xml
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.196
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a DIRECTV device with UDN = 29bbe0e1-1a6e-47f6-8f8d-0019dfba1923 and Friendly Name = DIRECTV Mediashare Renderer and adding it to the array with index = 2
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:InternetGatewayDevice:1 with FriendlyName = Xtreme N GIGABIT Router
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.250/root.sxml
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.250
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found Child device = urn:schemas-upnp-org:device:WANDevice:1 with FriendlyName = Xtreme N GIGABIT Router
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found Child device = urn:schemas-wifialliance-org:device:WFADevice:1 with FriendlyName = WFADevice
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.196:49152/virtual/description.xml
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a DIRECTV device with UDN = DIRECTV2PC-Media-Server1_0-RID-028895768621 and Friendly Name = DIRECTV2PC Media Server and adding it to the array with index = 3
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.197:49153/virtual/description.xml
12/5/2012 11:44:07 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a DIRECTV device with UDN = 29bbe0e1-1a6e-47f6-8f8d-80c6ab09f3a9 and Friendly Name = DIRECTV Mediashare Renderer and adding it to the array with index = 4
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:MediaRenderer:1 with FriendlyName = TV-55C6300
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.210:52235/dmr/SamsungMRDesc.xml
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.210
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPPort = 52235
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a Samsung Electronics device with UDN = f5cadfd4-2829-036a-bdd4-6598f8fee49b and Friendly Name = TV-55C6300 and adding it to the array with index = 5
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' isRoot = True
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' Description = Samsung DTV DMR
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelNumber = 1.0
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelURL = http://www.samsung.com/
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' hasChildren = False
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ManufacturerURL = http://www.samsung.com/
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelName = Samsung DTV DMR
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' IconIRL = http://192.168.1.210:52235/dmr/icon_LRG.jpg
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-ce-org:device:RemoteUIServerDevice:1 with FriendlyName = TV-55C6300
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.210:52235/ruis/Remo...DescLevel1.xml
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:MediaRenderer:1 with FriendlyName = TX-NR708
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.184:8888/upnp_descriptor_0
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.184
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPPort = 8888
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a ONKYO device with UDN = bfb0064d-0e06-4db9-4c0f-4d090eb907be and Friendly Name = TX-NR708 and adding it to the array with index = 6
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' Description = AV Receiver
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelNumber = TX-NR708
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelURL = http://www.onkyo.com/
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' PresentationURL = http://192.168.1.184/
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ManufacturerURL = http://www.onkyo.com/
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelName = TX-NR708
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' IconIRL = http://192.168.1.184/icon/onkyoB120.JPG
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:samsung.com:device:PersonalMessageReceiver:1 with FriendlyName = TV-55C6300
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.210:52235/pmr/Perso...geReceiver.xml
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a Samsung Electronics device with UDN = c01beddd-fb0a-b126-e4fe-9ccc35e52c08 and Friendly Name = TV-55C6300 and adding it to the array with index = 7
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' Description = Samsung DTV PMR
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelName = Samsung DTV PMR
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' IconIRL = http://192.168.1.210:52235/pmr/icon_LRG.jpg
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:MediaServer:1 with FriendlyName = DIRECTV2PC Media Server
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.195:49152/virtual/description.xml
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.195
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPPort = 49152
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice is adding a DIRECTV device with UDN = DIRECTV2PC-Media-Server1_0-RID-028896829976 and Friendly Name = DIRECTV2PC Media Server and adding it to the array with index = 8
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' Description = DIRECTV2PC Media Server 1.0
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ManufacturerURL = http://www.directv.com/
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~' ModelName = MediaServer
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found device = urn:schemas-upnp-org:device:HomeSeer:1 with FriendlyName = HomeSeer(HA1)
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found documentURL = http://192.168.1.190:16682/desc.xml
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPAddress = 192.168.1.190
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~FindUPnPDevice found IPPort = 16682
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~DetectUPnPDevices added a total of 9 devices
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~Warning in FindUPnPDeviceInfo for UDN = 29bbe0e1-1a6e-47f6-8f8d-0019dfba026f. The array does not exist
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~GetMACAddress called with IPAddress = 192.168.1.195
12/5/2012 11:44:08 PM ~!~DLNA Manager~!~GetMACAddress found entry with IPAddress = 192.168.1.195 and MACAddress = 00-19-DF-BA-02-6F
Gerard
