IFTTT, MyHS and the Echo should be functioning normally at this time.
IFTTT service down - Fixed!
Can I ask a question....
Can you have multiple IFTTT accounts linked to One HS installation...so...here's my thinking...
Each family member has IFTTT account which is triggering locations flags in HS...but that requires each family member to have an IFTTT account (which is fine) which tracks and triggers (thru IFTTT) location triggers (which is fine) to a single HS.(maybe)
Is this possible?
Darren
Originally posted by Bill Brower View PostIs there a strategy to do some sort of loopback test? I'm just getting into IFTTT. Something from HS3 that hits a phone and reports back to HS3 or HS3 hits the HS3/IFTTT server and loops back?
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Ultrajones View PostI created an ITTT heartbeat mechanism. It *should* notify me if the ITTT/HomeSeer mechanism fails. In summary, I have an ITTT Recipe that runs a "ITTT_Watchdog" event every hour that essentially sets a HomeSeer counter to 0. I have an ITTT_HomeSeer event that increments the counter by 1 every 7 minutes. I also have an alert event that sends me an e-mail if the counter ever reaches 10 or a multiple of 10. See screenshots.
Ultrajones
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Thank you!!!!
Thank you!!!!
Ultrajones
~Bill
IFTTT Not Working
Anyone else having issues with IFTTT as of today? When I try to create a trigger for DEVICE ON, the drop down box only says "Options Unavailable, try reconnecting your HomeSeer channel".
If I create a trigger using the DEVICE OFF, it sees all my devices and is current.
I have tried disconnecting and reconnecting multiple times and it shows it is successful but same issue occurs each time.
Any help would be appreciated.
Originally posted by minerpat View PostAnyone else having issues with IFTTT as of today? When I try to create a trigger for DEVICE ON, the drop down box only says "Options Unavailable, try reconnecting your HomeSeer channel".
Cheers
Ultrajones
IFFTT triggered event:
2016-09-26 19:04:31 IFTTT Heartbeat 271 seconds
2016-09-26 18:03:46 IFTTT Heartbeat 226 seconds
2016-09-26 17:04:59 IFTTT Heartbeat 299 seconds
2016-09-26 16:03:01 IFTTT Heartbeat 181 seconds
2016-09-26 15:03:29 IFTTT Heartbeat 209 seconds
2016-09-26 14:00:46 IFTTT Heartbeat 46 seconds
2016-09-26 13:03:38 IFTTT Heartbeat 218 seconds
2016-09-26 12:02:32 IFTTT Heartbeat 152 seconds
2016-09-26 11:03:15 IFTTT Heartbeat 195 seconds
2016-09-26 10:02:53 IFTTT Heartbeat 173 seconds
2016-09-26 09:01:53 IFTTT Heartbeat 113 seconds
2016-09-26 08:05:23 IFTTT Heartbeat 323 seconds
2016-09-26 07:04:02 IFTTT Heartbeat 242 seconds
2016-09-26 06:03:38 IFTTT Heartbeat 218 seconds
2016-09-26 05:00:12 IFTTT Heartbeat 12 seconds
2016-09-26 04:01:13 IFTTT Heartbeat 73 seconds
2016-09-26 03:02:33 IFTTT Heartbeat 153 seconds
2016-09-26 02:03:48 IFTTT Heartbeat 228 seconds
2016-09-26 01:04:27 IFTTT Heartbeat 267 seconds
2016-09-26 00:04:52 IFTTT Heartbeat 292 seconds
2016-09-25 23:01:04 IFTTT Heartbeat 64 seconds
2016-09-25 22:03:38 IFTTT Heartbeat 218 seconds
2016-09-25 21:00:16 IFTTT Heartbeat 16 seconds
2016-09-25 20:00:31 IFTTT Heartbeat 31 seconds
2016-09-25 19:04:29 IFTTT Heartbeat 269 seconds
HomeSeer triggered event:
2016-09-26 20:05:00 Check 5:00 0 seconds
2016-09-26 19:05:00 Check 5:00 0 seconds
2016-09-26 18:05:00 Check 5:00 0 seconds
2016-09-26 17:05:00 Check 5:00 0 seconds
2016-09-26 16:05:00 Check 5:00 0 seconds
2016-09-26 15:05:00 Check 5:00 0 seconds
2016-09-26 14:05:00 Check 5:00 0 seconds
2016-09-26 13:05:00 Check 5:00 0 seconds
2016-09-26 12:05:00 Check 5:00 0 seconds
2016-09-26 11:05:00 Check 5:00 0 seconds
2016-09-26 10:05:00 Check 5:00 0 seconds
2016-09-26 09:05:00 Check 5:00 0 seconds
2016-09-26 08:05:00 Check 5:00 0 seconds
2016-09-26 07:05:00 Check 5:00 0 seconds
2016-09-26 06:05:00 Check 5:00 0 seconds
2016-09-26 05:05:00 Check 5:00 0 seconds
2016-09-26 04:05:00 Check 5:00 0 seconds
2016-09-26 03:05:00 Check 5:00 0 seconds
2016-09-26 02:05:00 Check 5:00 0 seconds
2016-09-26 01:05:00 Check 5:00 0 seconds
2016-09-26 00:05:00 Check 5:00 0 seconds
2016-09-25 23:05:00 Check 5:00 0 seconds
2016-09-25 22:05:00 Check 5:00 0 seconds
2016-09-25 21:05:00 Check 5:00 0 seconds
Cheers
This seems weird to me. Usually IFTTT can react within a second or two.
I might have to do a test for this, though.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostThis seems weird to me. Usually IFTTT can react within a second or two.
How often do Recipes run?
It depends on the Recipe. Some happen within seconds. On average, most Recipes run within 15 minutes of being triggered.HS 4.2.8.0: 2134 Devices 1252 Events
Ultra
did your script catch the myhs outage this morning? It was down for just over an hour.
I was wanting to implement your script to monitor if it was able to pick up the outage.
ThanksHS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
It did work for me.
Cheers
