Hi All,
I have many older Aeotec inwall switches that work perfectly...i have momentary press wall switches attached, then detect the switch press in HS3 event and trigger other things.....I have recently purchased the newer 'better' unit....however after configuring it for momentary press via paramter 120, there is a 5-10sec delay between pressing the switch and HS getting the zwave notification....i am currently on zwave plugin .87. I tried .116 beta but same issue....Is this a known issue with the new gen5 nano? or is it an HS interpretation thing? As it is they are unusable.....I should note that if i connect a light to the output, when pushing the switch the light comes on within 0.5sec but still HS doesnt log the button pressed command till 5+ seconds later
