Phillipe,
We are a systems integrator in Costa Rica.
We do integration work for hotels and restaurants.
Up until the SqueezeBox plug in we were not able to consider HS as way to control media players because we were limited to only one player as hosted on the HS server.
The fact that we can add multiple RXers to a single network and allow control of all RXers as indpendent sources makes the HS and SB plugin look real attractive.
We have started playing with HS Touch.
And we have seen some primitive examples that work with MediaPlayer or iTunes as music sources.
We are looking for a sample HS Touch XML file that can control the SB RXers. (we have already shown basic control of a RXer with Volume, Mute, Pause, next, Prev) However we want to see playlists, albums, genres, artists much as is demonstrated in the HS Touch Sample-Project.
The problem that we are facing is the the SB Plugin does not seem to let the SB RXers appear as "Music System" thus the basic control templates that have been created by HS to allow for viewing and navigation of media content does not seem to work.
I was wondering if you had any experience with HS Touch, and if so, do you have any examples of Touch Projects that will allow me to fully control the RXer's content?
Thanks in advance for your support:
PS: We are running the SB 1.6 beta plug in, and the latest/greatest SB abd SC using SqueezeBox Duet. (We have ordered SB RXer V1, V2, V3 for further testing)
I look forward to your reply.
Sean Milligan
Sean Milligan
