This thread is to discuss the Arduino Plugin V1.0.0.36 that is in the updater.
Arduino Plugin V1.0.0.36.
Scripts = Various
Hi Greig,
I'm finally playing with this plugin and have a Mega connected with USB and a Uno over Ethernet. Both were easy to add. Thanks for making the plugin available!
Since I installed and enabled the plugin (1.0.0.36) , I see the occasional message like this in the HS Log:
Code:Jan-23 5:23:12 PM Info 25040 log entries retrieved, and this just added another!
Also, I prefer to use DHCP to assign static addresses to all my "infrastructure" devices. Is there a way to modify the ino file to retrieve the ip address via DHCP?
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by sparkman View PostAlso, I prefer to use DHCP to assign static addresses to all my "infrastructure" devices. Is there a way to modify the ino file to retrieve the ip address via DHCP?
AlHS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostNot to presume to answer for Greig, but you would still have to hard code the IP address into the plug-in, so I'm not sure it would be of any real advantage. I also use DHCP reservations for all of my devices -except- the Arduinos and my EDS OWServers.
Cheers
Originally posted by sparkman View PostThe advantages to me would be the ability to change them remotely (on the DHCP server and then the plugin page) and to keep track of all of my ip addresses in one spot (the DHCP server).
Cheers
Al
Can you not Reserve the IP in the DHCP table for the Arduinos?
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by enigmatheatre View PostI am not sure this would work as you would need the board to report the IP to HS which it is not doing at the moment. Can I ask why you would change the address once it is set?
Greig.
Cheers
Al
PS did you see my note about the log entry in my original post? Is it caused by the plugin?HS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by sparkman View PostPS did you see my note about the log entry in my original post? Is it caused by the plugin?
Scripts = Various
has anyone used analog inputs A2, A3, A4, A5 as digital inputs? i have an uno connected via Ethernet but when i assign them as standard inputs i can't get them to change but if i assign them as analog inputs they work fine? I then map the value with "Value*2/1023" so it will show 0 or 1.xxx but i am just wondering if i should try something else or if you can't use the analog inputs as standard inputs without using the API mode
Originally posted by usLEDsupply View Posthas anyone used analog inputs A2, A3, A4, A5 as digital inputs? i have an uno connected via Ethernet but when i assign them as standard inputs i can't get them to change but if i assign them as analog inputs they work fine? I then map the value with "Value*2/1023" so it will show 0 or 1.xxx but i am just wondering if i should try something else or if you can't use the analog inputs as standard inputs without using the API mode
25 = A2
26 = A3
27 = A4
28 = A5
I hope this helps you.
Scripts = Various
Originally posted by usLEDsupply View PostWith the UNO R3 i had to use the following pins to use the analog pins as digital inputs
A0 = 14 (not usable as isn't in the pin list)
A1 = 15 (as long as you have a newer Ethernet Shield)
A2 = 16
A3 = 17
A4 = 18
A5 = 19
I am looking at a way to make it work by selecting the A0-A15.
Scripts = Various
I think you could map A0 to 14 and so on but i think you would need a way to select the board you are using in the setup (mega or uno) so you don't loose use of those pins if it is a megaLast edited by usLEDsupply; January 25, 2015, 02:06 AM.
