Go Back   HomeSeer Message Board > Gaming Related Plug-ins > Gaming Related Discussion > Kinect (3P)
Kinect (3P) Discussions related to the Kinect plugin for HS3.
Old May 6th, 2018, 08:42 AM
wadesready wadesready is offline
Seer Deluxe
Kinect broken after win10 1803 update
spud
I updated all my pc to the latest win10 and it appears to have broken my kinects. I have two remotes and a local and they all act the same way. log below is for the local kinect. It loads, says it build all the grammers, and then stops
May-06 8:34:57 AM Kinect DEBUG Trying to restart Speech Recognition May-06 8:34:57 AM Kinect TRACE - AudioPosition = 00:00:00; InputStreamEnded = True May-06 8:34:57 AM Kinect DEBUG Speech Recognition Stopped May-06 8:34:57 AM Kinect DEBUG Speech Recognition Started May-06 8:34:57 AM Kinect DEBUG Rule (Devices) set [the] [Node 49] [Bedroom] Front LED Lights to Colored May-06 8:34:57 AM Kinect DEBUG Stopping Speech Recognition
Last edited by wadesready; May 6th, 2018 at 09:08 AM. Reason: needed to...found it...changing privacy settings on mic
Old May 9th, 2018, 08:04 AM
spud's Avatar
spud spud is offline
Moderator
have you figured it out?
Old May 9th, 2018, 08:17 AM
Seer Deluxe
Quote:
I did spud. the update changed the privacy settings on mics and I only had to enable the mic access to apps and it fixed it. thanks
Old May 15th, 2018, 10:14 AM
Pete's Avatar
Pete Pete is offline
OverSeer
Well today I would say that Windows 10 is more of an AI entity then just a tool to use.
Many of the more recent updates are dealing with the Microsoft Cortana all knowing entity.
It'll take care of you because it knows you now.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
HTML code is Off
Was it me or Win10 V1709 that broken my HS3 studeimus HS3 / HS3PRO Discussion 4 December 6th, 2017 09:20 PM
Win10 "Speak" not working after Remote Desktop Connection, connect.bat for Win10 not garwood HS3 / HS3PRO Discussion 4 November 1st, 2017 02:50 PM
Was there an auto-update? Web access broken lhfarm HS3-Pi Discussion 21 October 19th, 2017 10:41 AM
Update Temp Sensor Map feature broken? ekuykendall MCS Temperature 3 January 9th, 2003 10:17 PM
