Originally posted by jon00
View Post
Jon00 Homeseer 2 - Homeseer 3 - Homeseer 4 Connector
ok it crashed again, only one instance running and no error report in HS2Gateway only this slash screen which I think is HS generated,16/01/2016 18:16:20
Stream is closed.
HomeSeer version: 2.5.0.81
Source: System.Runtime.Remoting
Target: Int64 Seek(Int64, System.IO.SeekOrigin)
Stack trace:
at System.Runtime.Remoting.Channels.ChunkedMemoryStream.Seek(In t64 offset, SeekOrigin origin)
at Belikov.GenuineChannels.Messaging.GenuineChunkedStream.Seek( Int64 offset, SeekOrigin origin)
at Belikov.GenuineChannels.Messaging.GenuineChunkedStream.set_P osition(Int64 value)
at Belikov.GenuineChannels.GenuineTcp.TcpConnectionManager.LowL evel_EndSending(IAsyncResult ar)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.ContextAwareResult.CompleteCallback(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.ContextAwareResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortC allback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCa llback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Please specify what you were doing at the time of this error:sigpic
Originally posted by jon00 View PostGogs,
Your system must be unstable. With your repeated issues, re installs and .NET framework repairs, it's time to upgrade to a new OS and probably a new computer.
So Here is hoping, will keep you posted.sigpic
Your system must be unstable. With your repeated issues, re installs and .NET framework repairs, it's time to upgrade to a new OS and probably a new computer.sigpic
Originally posted by jon00 View PostDoes that mean you will ditch HS2?7/01/2016 23:59:53 ~!~Network~!~Remote client connected from: 192.168.1.4
17/01/2016 23:59:53 ~!~Network~!~Remote client connected from: 192.168.1.4
17/01/2016 23:59:54 ~!~Network~!~Remote client connected from: 192.168.1.4
17/01/2016 23:59:55 ~!~Network~!~Remote client connected from: 192.168.1.4
17/01/2016 23:59:56 ~!~Network~!~Remote client connected from: 192.168.1.4
17/01/2016 23:59:57 ~!~Network~!~Remote client connected from: 192.168.1.4
17/01/2016 23:59:58 ~!~System~!~Switching to a new log file.
17/01/2016 23:59:58 ~!~Network~!~Remote client connected from: 192.168.1.4sigpic
Originally posted by jon00 View PostI can't really advise...I have never seen disconnects like that. It must be either another plugin in HS2 or something wrong with your TCP/IP stack.sigpic
Originally posted by jon00 View PostLinux is not going to help you as HS2 only runs on Windows. If you intend to run HS2 on the same PC as before, I doubt there will be any change.....
Thanks cfor your opionion.sigpic
Originally posted by jon00 View PostNot in my books.
Personally, I would try a later version of Windows on the PC.
have alook at this beast for sale, hat do you think/
http://store.homeseer.com/store/Home...ler-P1853.aspxsigpic
