Originally posted by kenrad
View Post
To also run a Homeseer 2 event, you need to add the following action:
Select "Run a script or script command"
Tick the "Immediate Script Command" check box. You may need to press the red Aeroplane button to see this.
In the "Execute immediate script command" text field enter:
&hs.savevar("jon00gw","Event <name of the Homeseer 2 event>")
That all to it!
The attached screen shots show the Homeseer 2 event "Update Weather" which would be run if the Homeseer 3 event is run.
There appears to be a bug in Homeseer 3 so until it is rectified, you cannot run Homeseer 3 events this way from Homeseer 2.
