BLControl 1.0.46 - Local vs Remote WIFI
    I have made a change in the BLControl app to help detect whether you are using local or remote WIFI
    I have a new setting where you can enter you local WIFI SSIDs (to enter multiple just separate them with a comma)
    If BLControl detects you are on Wifi and the SSID is one of your local SSIDs then it will use the internal URL for connecting, otherwise if the SSID is not one of your SSIDs then it will use the external URL.
    Cheers,
    Bob
    Blade, one other idea, that I use on HSTouch, is to detect if the client is coming from a particular IP address(es) that are assigned to my VPN. For example, if the client is on VPN, then the camera feeds used are a much lower snapshot per second, whereas if local the client gets a full speed live video feed.
