New HS3 Icons are Coming!
Originally posted by rprade View PostHasn't it been that way for a while?
Originally posted by macromark View PostWe're doing status icons now, not device icons. That's a whole 'nuther project. in fact, we adding changing the device image column to be an optional view column._______________________________________________
Originally posted by jlrichar View PostI like the device image column. I'm not sure why, since it doesn't "do" anything, but all the same I like it. For physical devices I use images of them that I manually found on google image search. For virtual devices, several plugin authors use large icons for the device images (Spud's plugins for example). It adds a nice polish to the plugin IMHO.
Originally posted by macromark View PostWe're creating a new set of status icons for HS3. Here's a preview.
Note that the new set will become the "default" set in HS3. However, you'll be able to continue using the old "Classic" set if you prefer.
Mark, will you have the following icons; if not, can I request for them:
- combined icon for door closed + locked & door closed + unlocked
- windows open & closed
- roller shades open & closedHW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
Originally posted by macromark View PostThe window icons will be part of the base set. However, those will need to be assigned manually. Apart from that, I'll provide a Photoshop file that will simply include the standard background color circles and anyone (with Photoshop) will be able to add their own white icons to that file to create their own icons.Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Originally posted by gearyt View PostPERFECT !!! This should be a great year for HS with all the press about home automation... I see TV commercials every night
Originally posted by macromark View PostWe should do a KickStarter campaign to fund a national TV commercial. That would be fun.Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
I'm not sure you could get a kickstarter for a commercial, but I don't believe it costs anything to try.. Of course most kickstarters have "perks" so you have to factor that cost in. IT could just be "Be a part of our commercial" and stuff like that.
