I was tinkering with this over the weekend and decided to add Google Home control to the TV in the bedroom. Works pretty well! Commands like "OK Google, turn on the TV" and "OK Google, turn on CBS" can be done by creating virtual devices "TV" and "CBS", adding "TV" and "CBS" to the respective Voice Command fields and then creating events that send the sequence of IR commands when the virtual device has it's value "set to" ON. Be sure to use "set to" instead of "changes and becomes" since the (CBS) device is forever ON once you've set it to ON.
MeiHarmonyHub version 3.0.3.5 (beta) is now available!
Originally posted by macromark View PostI was tinkering with this over the weekend and decided to add Google Home control to the TV in the bedroom. Works pretty well! Commands like "OK Google, turn on the TV" and "OK Google, turn on CBS" can be done by creating virtual devices "TV" and "CBS", adding "TV" and "CBS" to the respective Voice Command fields and then creating events that send the sequence of IR commands when the virtual device has it's value "set to" ON. Be sure to use "set to" instead of "changes and becomes" since the (CBS) device is forever ON once you've set it to ON.cheeryfool
Just brainstorming here
Originally posted by cheeryfool View PostAnother route for this is linking Harmony directly to Alexa. Alexa discovers Harmony favourites and you can say "Alexa, turn on CBS". Granted, this bypasses HS, but it's seamless and less effort to setup.
Originally posted by sirmeili View PostI will be adding "Macros" to the plugin which should make this a lot easier. Mabye I could write in something like the option to create a device to trigger the macro? Each macro would have a setting for this so as to not inundate HS with a bunch of needless devices.
Originally posted by macromark View PostAlexa and Google Assistant only know about HomeSeer 'devices'... so if you're going to launch a macro from one of these voice assistants, it needs to be done with devices, I believe.
So, say you create a macro for starting CBS: Turn on Activity "Watch TV", wait 2 seconds, send channel number
Then I could create a device called "CBS" with an "on" button which you could set up in Google home or Alexa.
This allows you to simplify the creation process instead of having to create a device on your own, and then create an event to handle it.
Originally posted by sirmeili View PostYeah, that's what I mean. I could have an option when you create a Macro in the plugin to also create a device in HS that could trigger it.
I have all of my media events turn off the virtual channel devices when the physical device is turned off. This way I can go between channels. If I turn on "ABC" for example it turns on the TV, turns on ABC, turns off CBS, Chromecast, etc.
I had a MeiharmonyHub plugin induced HS3 crash today running plugin version 3.0.3.4. The crash wiped the HS3 license file. HSsentry restarted HS3 but it hung waiting to accept the trial. Fortunately I had a copy of the license file.
The crash was recorded by Windows 10 reliability history, a handy utility.
I updated to 3.0.3.5 tonight, I'll see how it goes.
Originally posted by mterry63 View PostI had a MeiharmonyHub plugin induced HS3 crash today running plugin version 3.0.3.4. The crash wiped the HS3 license file. HSsentry restarted HS3 but it hung waiting to accept the trial. Fortunately I had a copy of the license file.
Sent from my Pixel 2 XL using Tapatalk
hi,
I still; have a problem when a hub disconnects with .5 version;
Code:apr-10 10:16:57 MeiHarmonyHub: Error The Conection to Hub with ID 60592f43-fe8b-4ad7-2ecf-d32f44d58e45 failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml) at HarmonyHub.Client.OpenStream(Int32 heartbeatInterval) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) apr-10 10:16:57 MeiHarmonyHub: Error The Conection to Hub with ID 60592f43-fe8b-4ad7-2ecf-d32f44d58e45 failed with message: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
I forced an AP reboot, which disconnect my hub, but it reconnects and is available in the app etc. However, sometimes the plugin will keep giving these errors. If i stop the plugin and restart the plugin, the errors are gone.
Any thoughts?
BartRegards Bart
Win7 64Bit on Intel NUCI7 with SSD
HSPRO 3.
Devices; 1370 Events; 691
Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
Any thoughts?
Bart
Is this running on Windows or Linux?
hi,
Its on windows. I am running a UNIFI setup at home. But in addition i have 4 hubs, which are connected to same vlan and ap. which doent have that issue at that moment, so not likely its the firewall then in that case i guess.
However i had some issue with the unifi setup last week..
BartRegards Bart
HSPRO 3.
Bart
It's not a great test because it could still be something on the windows machine blocking it (windows firewall or something else blocking it), but it might show if it's the hubs at least.
Do all 4 of them not connect?
Originally posted by sirmeili View PostOut of curiousity, how do you know the plug-in caused it? And do you happen to have any logs so I can try and prevent it in the future? ;Windows logs, home see logs anything to try and point me to the cause).
Here are the details from that utility. Unfortunately, the crash corrupted the HS3 log file.
Description
Faulting application name: HSPI_MeiHarmonyHub.exe, version: 3.0.3.4, time stamp: 0x5ac2fc71
Faulting module name: KERNELBASE.dll, version: 10.0.15063.966, time stamp: 0x643391f2
Exception code: 0xe0434352
Fault offset: 0x000ecbc2
Faulting process id: 0x12c8
Faulting application start time: 0x01d3cb734bfbd508
Faulting application path: C:\Program Files (x86)\HomeSeer3\HSPI_MeiHarmonyHub.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 894636cc-bd5f-4fe9-b575-e5463a37f5c2
Faulting package full name:
Faulting package-relative application ID:
