Send device commands through event
    I'll check it out. I thought I caught all of these when I moved to storing the settings in files, but I could have missed this one.
      In case it helps at all, I am triggering events from HSTouch and sending device commands through this plugin and everything is working great.
      I am running plugin version 3.0.2.0.
      I only have one hub in one room, but so far, I have been able to make it do everything I have wanted to. I am just testing still and will likely be purchasing this week, but for me it has been very reliable and functional to this point.
      My use case is pretty simple, when I press a button in HSTouch run 'x' event, which powers on a TV using IR through a device command with this plugin and sets a bunch of other functions on other devices outside of this plugin, including the Meiku plugin also provided by sirmeili.
      -harshl
        Im using version 3.0.3.8. When I try an d select a device from the drop down selector I always get the lines (no device) immediately after I select the device. How can I get the 3.02 version?
          Yes, sorry, which all the stuff that was going on with my Son, I really dropped the ball on this one. I will be looking at this tonight.
          Note that I fixed some of these issues in 3.0.3.9.
            I just tested in 3.0.3.9 and it works. If you are running .435 of HS, I would hold off if you aren't having any issues. I think something is casing the plugin to crash after disconnects on the newer version of HS for some reason.
              I am using the following HS Version
              HomeSeer Version: HS3 Pro Edition 3.0.0.425
              Where can I find the .39 version? Its not in the updater.
              Bob
                The version in the updater is 3.0.3.10 which is newer than 3.0.3.9 and should have the fix.
                I think you are running 3.0.3.8, right?
                  Yep that worked. Able to create event with it now. Thanks!
