Any update Blade? Just wondering if you could see anything from these logs?
LOCK INFORMATION NEEDED -- BLLock for HS3
I've got the latest version and went in to check I had the new on set up correctly. I have re-setup the users. It won't let me have a user 5 for some reason. After entering the users with the numbers as defined on the lock, I then unlocked the door using my own code and it comes up unlocked by Cleaner. When it spoke, it was consistent with this user at least. It is speaking twice for some reason still. It also said the lock had changed to lock (and the speech consistently said Cleaner has locked the door, when I had entered the code and thus unlocked the door).
Finally - and unrelated to these issues I'm getting - is there a way to point to the speaker at Sonos? On events it is possible to change the speaker client, but you have to manually amend the speaker client list. The plugin just reads this list, so I can't change it.
I am seeing this in the log:
03/10/2017 08:41:18:890 PM : v2.0.61.0 - HSEventFunctions.Process_HS_Event(): devRef --> 469
03/10/2017 08:41:18:890 PM : v2.0.61.0 - HSEventFunctions.Process_HS_Event(): address --> 0161DD7C-063-Q9
03/10/2017 08:41:18:890 PM : v2.0.61.0 - HSEventFunctions.Process_HS_Event(): newValue --> 1007
03/10/2017 08:41:18:890 PM : v2.0.61.0 - HSEventFunctions.Process_HS_Event(): oldValue --> 1
03/10/2017 08:41:18:890 PM : v2.0.61.0 - HSEventFunctions.Process_HS_Event(): fullDeviceCode --> Q9
This is user 7 which according to your list would be Erika.
