RFXCOM HS3 plug-in (HS4 compatible)
    Version 30.0.0.0 7-9-2013
    new or changed:
    - major version number changed to 30 (for the HS3 Updater)
    corrections:
    - Panic selection not saved on the Alarm Control Panel
    - Not possible to add RFXSensor humidity sensor to a Daily humidity virtual sensor
    Version 30.0.0.1 11-9-2013
    new or changed:
    - Supported receivers and RFXtrx supported incremented from 4 to 6
    corrections:
    - Rain rate displayed with 1 decimal
    - Protocol selection boxes deselected for unused RFXtrx and receivers
    - Active devices appear again in the Heard Lists
    - WDS500 not detected
    - Communication failures not detected
    - Status of Motion sensors not set to normal after 2 minutes
      Version 30.0.0.2 12-9-2013
      new or changed:
      corrections:
      - communication failures on remotes and weighting scale
        Version 30.0.0.3 18-10-2013
        new or changed:
        - Transmitter config added
        - Output devices added
        - X10 settings added to the Interface Panel
        - Receiver and RFXtrx/RFXrec parameters configured stored in the device
        - WS1200 Temperature Rain sensor added
        - Byron SX Chime added
        - Energenie ENE010 added
        - Receive of X10 lighting sensors (full function not yet supported)
        corrections:
        - Enable/Disable button was present for inactive security sensor
        - sensor not processed after change of sensor ID, restart was necessary
        - XmitRXChar error solved
          Version 30.0.0.4 25-10-2013
          new or changed:
          - Livolo dimmer and appliance added
          . RF models at http://www.aliexpress.com/store/all-...ts/500715.html
          - Siemens extractor hood added
          corrections:
          - receiver config was not correct set if updated from 30.0.0.2
            Version 30.0.0.5 19-11-2013
            new or changed:
            - Maverick ET-732 added
            - Alecto SA30 added
            - Oregon EW109 added
            - AC input device can be controlled now
            corrections:
            - CM180i total power usage corrected
            - Input device sensor ID change corrected
            - Output device values set by events are now processed
              HS3 Version 30.0.0.6
              new or changed:
              - Linux support
              - 32 bits RFXCOM and W800 receivers supported
              - Received RF X10 lighting commands forwarded to the power line (with use of the X10 plug-in)
              - Digital I/O lines supported on the RFXCOM LAN devices (Output: for example RFXio,KMtronic SS_8REL5V or input of dry contact)
              - RGB LED controllers added (dx.com ordernr 67412 and 130913)
              - Plug-in configuration parameters moved to the X_IFACE[1]Q device.
              - Event triggers on message panel string added
              corrections:
              - Alarm panel control corrected
              - X10 configuration does no longer need a plug-in restart
              - False double triggers removed
              - Panic status added to Security remote and Security sensor
                HS3 Version 30.0.0.7
                new or changed:
                - Pushbutton commands accepted independent of the state
                - RGB slider disabled by an OFF command, enabled by an ON command
                - MDremote added
                - KD101 as siren added
                - X10 power On/Off/All On/All Off supported. (Dim/bright is not yet supported by the X10 plugin)
                - RFXCOM HS3 User Guide available in the HS3 Docs directory
                corrections:
                - BBQ sensor no_signal icon corrected
                - NMA error message during startup solved
                - Transmitter without interface configured did not show the Not used status
                - Icons corrected for use in Linux
                  Version 30.0.0.8
                  new or changed:
                  - Virtual Security sensors added
                  corrections:
                  - HSEvent error messages solved
                  - Chill calculation corrected
                  - Transmitter for security correct saved.
                  - Error message (InitVariables) NMA priority not numeric solved
                  - Digital I/O toggle corrected
                    Version 30.0.0.10
                    new or changed:
                    corrections:
                    - Delete Digital I/O devices corrected
                    - CheckSensors updated with check on device exists to avoid error messages
                    - HSEvent error messages corrected
                      Version 30.0.0.11
                      new or changed:
                      - Input message panel created when the 1st Input sensor is configured
                      corrections:
                      - device delete corrected
                      - Virtual wind gust sensor corrected
                        Version 30.0.0.12
                        new or changed:
                        - Address optional and free to change by the user
                        - Import Security device function added
                        - Import Input device function added
                        - Import Virtual device function added
                        - Import Output device function added
                        corrections:
                        - Updater problem fixed
                        - Mertik control corrected
                          Version 30.0.0.13
                          new or changed:
                          corrections:
                          - DevCmd errors solved
                          - Output device HC/DC configuration corrected
                          - Alarm panel enabling corrected
                          - Sensor ID change corrected
                          - Sensor battery expire messages where displayed in alarm message panel
                            version 30.0.0.14
                            new or changed:
                            - Status text updated on language change
                            - Function SetAlarmPanel does not need Unlock
                            corrections:
                            - HomeEasy EU unit code was not configurable
                              Version 30.0.0.15
                              new or changed:
                              - Save button changed to Done and order changed on device config pages
                              - Update device button added to RFXCOM Device config pages.
                              - CM180i added for RFXLAN and USB receiver
                              corrections:
                              - Conversion problem in 30.0.0.14 with devices that have a HC/DC assigned solved
                              - Communication Failure timeout was not configurable
                              - Alarm Panel status not correct set
                              - Init of "Use unlock also for Arm Buttons" corrected
                              - ARC Chime corrected
