My hot water heater is 220v. The wire providing power has two 110v legs and a ground. There is no common.
I have an Insteon EZSwitch30 #4030A that I want to use to control the water heater. When I am away, I want to turn off the heater to save energy and then be able to remotely turn it on before I arrive back home. The 4030 uses the common for commands.
In thinking about it, it seems to me I could bring in a common from a nearby 110 outlet to the 4030.
Do you see any reason this will not work?
