I just added a two Aprilaire 8870 thermostats to my Elk system. The Elk M1 Plug-in does a fantastic job monitoring the settings and controlling the HVAC in my house.
What I was hoping to do was report when the AC or Heat is actually running. I can adjust the setpoints, change the modes, turn the fan off or Auto but is there a way in HS to have an event trigger a virtual device to indicate the that AC is on?
I thought I could compare the T-Stat current temperature with the setpoint using an event but do not see that option using the plug-in.
Am I missing something, anyone else have a typical setup?
Thanks.
Thanks.
