I may have missed something and have not found any references to this problem using the search feature - thanks in advance for any advice regarding this problem.
The problem is this: When sending an email to HS to trigger an event HS triggers the designated event and then proceeds to trigger every other event configured for an email trigger - if there are six events configured for email triggers (yes, they all have different names...) all the events are triggered in succession even though only one email with, for example, "triggerevent1" in the message header is received, HS triggers that event and then proceeds to trigger events 2-5 immediately thereafter.
This is a new installation, version 2.5.0.49. This is in a rural area, there is no phone service and the internet connection is via a wireless (not satellite) service using NAT, so the web server is not reachable. The system is running XP and Outlook Express - I've tried other email clients with no change in behavior. There seems to be no problem with either receiving or sending email from HS.
Thanks again.
Thanks again.
