UltraWeatherBug for HS2 / New WeatherBug Pulse API
I uninstalled the plug-in and started fresh.
I didn't get the errors but it is still not working.
It now shows no stations.
Prior to doing the re-install Valid Key was "False" and "Success" was zero and "Failure" was several hundred and there were a lot of errors including one that indicated "The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel." See prior post for more.
After the install Valid Key is showing "False" with "Success" at zero and "Failure" at zero. But there are no errors in the log indicating a failure to connect like before.
I went to the web site and confirmed that I copied the entire consumer and secret key. What I copied into the fields are the correct keys.
I verified that I have .net Framework 3.5. I also have 4 and 4 Extended.
I am running HS2PRO
Originally posted by pcp View PostA few notes / questions
- I appears that the "Rain Rate" and "Rain Month" are the same value
- Are the APIs supported to fetch station current condition and forecast information?
I am using the APIs in one of my script:
- Station("current-condition")("Value") returns 4 (i.e. the value) instead of "Partly Sunny"
- How would I build the URL to the icon? I used to use the code below
PHP Code:Dim strCondition As String = Station("current-condition")("Misc")
Dim strImageSize As String = "65x55"
Dim strImageType As String = "trans"
Dim strConditionIcon As String = String.Format("http://img.weather.weatherbug.com/forecast/icons/localized/{0}/en/{1}/cond{2}.png", strImageSize, strImageType, strCondition)
PHP Code:Dim strDayName As String = DayOfWeek("ShortName")
Dim strShortPerdiction As String = Forecast(strDayName)("short-prediction")
PHP Code:DaysOfWeek #0 key = ShortName , Value = SUN
DaysOfWeek #0 key = LongName , Value = Today
DaysOfWeek #0 key = ForecastName , Value = 0 Day
DaysOfWeek #1 key = ShortName , Value = MON
DaysOfWeek #1 key = LongName , Value = Tomorrow
DaysOfWeek #1 key = ForecastName , Value = 1 Day
While the UltraWeatherBug plug-in may look similar to the old one, everything is a lot different under the hood. Can you get the values you need from the HomeSeer device instead of the hashtables?Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by noopara View PostI uninstalled the plug-in and started fresh.
I am running HS2PRO
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
For Alerts there is a device for the Alert type and title. Can the summary be added to a device as well (Edit: actually for all $ options available in when composing the Alert Wheater Template each in a separate device)?
If more there is more than outstanding Alert, can they/could they be added to separate devices (type/title/summary for each)? Maybe the based on maximum configured in the options.
Well if updating Root Certificates takes some action on my part to make it happen then the answer is NO. In fact, it's NEVER.
I don't have a clue what you are talking about or how to go about it.
I am using a PRO100 embedded XP system.
I take it back, I do know a little about what you are talking about - but not a lot. I did a little googling and found that updates are available for download from MS. I'm not sure how this works with an embedded XP system. What happens down the road since xp has been dropped by MS? Is my $2500 PRO100 going to unusable at some point in the future?Last edited by noopara; May 9, 2014, 05:15 PM.
The Secret key is configured as a password field. When you click save, the secret is stored in the configuration file. It is not displayed in an effort to keep it a secret :-)
Once you enter your Pulse API key information, are you able to select a WeatherBug station?
Originally posted by Ultrajones View PostWhile the UltraWeatherBug plug-in may look similar to the old one, everything is a lot different under the hood. Can you get the values you need from the HomeSeer device instead of the hashtables?
Missing devices - Current
- detailed description
Missing devices - Forecast
- day name (for day 2 & 3 especially)
- humidity
Missing devices - Alerts
- post date ($posted-date)
- expiry date ($expires-date)
- message summmary ($msg-summary)
- more than one alert in devices (up to 5 devices per alert: type, title, summary, posted date, expiry date)
Hi Ultrajones,
I deleted the old station and have set the same as the new one.
Now it seems to work.
But every 15 minutes I get the error message :
10.05.2014 23:09:11 UltraWeatherBug Error An unexpected error occured in the SetDeviceValue() function/subroutine: [System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. bei HSPI_ULTRAWEATHERBUG.HSPI_WEATHERBUG.SetDeviceValue(String strStationNumber, String strKeyName, String strKeyValue)]
Where is the issue ?
Regards, Fischi
Regards, Fischi
Originally posted by Kaje View PostInstalled it and...ahhh...good to have my weather devices running again!
Only issue I have is in the log I'm seeing
5/6/2014 11:56:53 AM ~!~UltraWeatherBug Info~!~https://thepulseapi.earthnetworks.co...oken=zzzzzzzzz
5/6/2014 11:56:54 AM ~!~UltraWeatherBug Error~!~An unexpected error occured in the SetDeviceValue() function/subroutine: [System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG.HSPI_WEATHERBUG.SetDeviceValue(String strStationNumber, String strKeyName, String strKeyValue)]
I have two stations identified and see the error twice. No error on the 'Alerts' and 'Forecasts'.
Best I can tell all of the data is populating fine.
Ken J.
HSPRO 2.5.0.80, ADIOcelot 1.14.0.11, HSTouch Server 1.0.0.72, iAutomate RFID 1.1.0.0, NetCAM 1.1.0.1, TED 1.2.0.3, UltraMon 1.1.4834.30105, UltraWeatherBug 2.5.0.0
106 Z-Wave nodes, 3 Z-Trollers, Ocelot (4 SECU16, 1 Relay8, 6 Bobcat T), 9 iAutomate tags, Schlage Locks
