Label Message Updates
    Hi Bob,
    When I use function calls to update text and string labels, the changes are not reflected in the INI file. The INI file is only updated if the text and string labels are edited through the plugin web interface. The effect of this is that when the plugin restarts, it displays whatever is in the INI file which tends to be outdated. Is this by design? Would it be possible that when the text and string labels are updated using the function calls that the changes are also reflected in the ini file?
    Al
    PS BLLED has been working great for me and the signs get rave reviews from visitors (mainly from the men ). They all ask where they can get one assuming that it just works by plugging it in, not realizing all the bits and pieces it needs to make it work.
    That is by design.
    I could likely make it an option to enable that.
    Add a feature request
    Cheers,
    Bob
      Thanks Bob, done.
      Cheers
      Al
