Face Recognition plug-in - Beta testing
    #46
    Originally posted by steveng View Post
    Thank you that worked, its always in the details. i missed the /zip in the instructions.
    I will give it a try and let you know any issues.
    Steven
    you need kinect plugin version >= 3.0.0.26 to avoid these errors
      #47
      Kinect users,
      I have released version 3.0.0.29 of the kinect plugin which includes some fixes to use it with the FaceRecognition plugin.
      do not forget to add the .jpg hint at the end of your url in the FaceRecognition config page:
      http://<ip_of_kinect_instance>:8078/kinectsnapshot?.jpg
      and if the FaceRecognition and Kinect plugin do not run on the same machine, you need to make sure that there is no firewall that blocks the 8078 port on the kinect machine.
        #48
        having problems with my camera as well.. see attached
        Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
          #49
          here's how I set it up
            #50
            added .jpg as noted above, software will not "start"
              #51
              log results...
                #52
                Hi Gearyt, can you try this url.
                http://192.168.1.143/axis-cgi/jpg/image.cgi
                Your url goes to a webpage and not the real image.
                Tasker Plugin / Speech Droid
                Tonlof | Sweden
                  #53
                  the url you are using is not a video stream, it's a html page (with menu, buttons, etc) inside which you can see the video stream, but you can't use it in the FaceRecognition plugin as it not able to use html as source input.
                  according to the user guide for the Axis Q7404 I found here http://www.use-ip.co.uk/datasheets/a...usermanual.pdf
                  you should be able to use this url
                  http://<ip>/axis-cgi/jpg/image.cgi
                  in your case I guess it would be
                  http://192.168.1.143/axis-cgi/jpg/image.cgi?.jpg
                  Note that you need to add the ?.jpg and to tick the snapshot mode checkbox because it is a still image url, not a real video stream
                  try first in a browser and let me know
                    #54
                    no change..
                      #55
                      went back tic'd the snapshot box... no change
                      see error, missing ?
                        #56
                        woo hoo..
                          #57
                          try first in a browser, if the url doesn't work in a browser, it won't work in the plugin either
                            #58
                            soooo... where should I see the camera feed ?
                              #59
                              I thinks we be there !! ;>) Off to RTFM and wait for momma to come home... any idea on the response time yet ?
                                #60
                                Key word " will run on the machine HS is running on ".. I was logged on remotely
