I have my Z-net working and tried to add a new garage door sensor but the device seems to be unable to get the security scheme. I'm holding it right next to the Z-Net. my Z-net is 1.0.9 and plugin is 3.0.0.209. Any help on this?
Z-Wave manufacturer information for node 40, ID: 335=14FH (Linear), Type: 18244=4744H, ID: 12336=3030H
Negotiating or Verifying SECURITY SCHEME for node 40
Warning: Failed to get a SECURITY SCHEME or verify the key from node 40. Device may not be added properly to HomeSeer.
Warning: The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first)
Warning: If this device was previously added to the network, the device may need to be removed from the network and re-added.
Warning: In case the device was previously added successfully, an attempt will be made to continue the import.
Getting SECURITY class information for node 40
Node: 40 Supports Class(es): MANUFACTURER_SPECIFIC, SECURITY, DEVICE_RESET_LOCALLY
Node: 40 Supports Secure Class(es): VERSION_V2, BARRIER_OPERATOR, APPLICATION_STATUS, ALARM_V2, ASSOCIATION
All associations for node 40 have been retrieved successfully, it supports associations on these groups: 1.
