I have a power sensor CM180i, and somehow last night it got 'stuck'. It is reporting 123 Watts, even though it should have been (and still should be) 0, I think it might have been caused by a communication issue. It might correct itself if and when there is power to report, but its likely to be 0 for a while. But I am using its value to calculate other things and that screws everything up... so I would like to somehow reset it to 0 but cant do it. I have restarted the system but that didn't help, its still showing 123 Watts... I have run a script to set the device string to false and tried to set the value to 0 but it hasn't worked
Cannot reset a value from CM180i
Originally posted by b_weijenberg View PostWhat is the status of the battery sensor of this device?
To set the device value to zero you can use &hs.setdevicevaluebyref(57,0,true)
But the device string will not be changed by this command.
This set the value to 0, but I think I need to set the device string to 0 too, its still showing that value
I have sent a &hs.setdevicestring 57,"0",true which now has reset it to 0Last edited by mikee123; December 20, 2016, 08:22 AM.
Originally posted by mikee123 View PostBattery is showing as low, looking at advanced its 25%
