Thermostat not being discovered
    Hi all,
    so, everything works with the new skill, apart from my thermostat, which is not discovered.
    Now, from the forums, Sgt Schultz says in one thread that thermostats with text box set points need a virtual device. I tried this, but if I ask alexa any combination of "set device to x", I get "the command does not work on that device"
    So I'm kind of stuck. The thermostat set point device is never discovered (yes, the voice control tick box is set, and the status options are set to drop list and heat setpoint). If I enable the root device for voice control, it sees the root device, but you can't do anything with that either.
    Has anyone got a proper guide to how to get this to work, for those interested in what the stat is, it's a Horstmann z-wave thermostat that just has a heat setpoint.
    *bump* any ideas?
