POTS Line to Cellular Modem
    I have family that raises chickens, lots of chickens. They have some sort of controller which monitors Temp, Power and other telemetry. Apparently if something is amiss, it will call them. I'm guessing there's a robot voice saying something is wrong. Anyways, the phone line has been out for two weeks apparently, and they want me to investigate moving to a Cellular Modem. Not really my area of expertise. I would say if it has a POTS line it's time for an upgrade right away.
    Anyways, so a Cellular Modem with a POTS line connection which provides a dialtone? Fascimile Cellular Modem?
    AT&T Home Internet. It's a cellular modem with a standard RJ11 jack for connecting a phone. It's an always on solution intended to replace a normal phone line.
      They have Verizon, and they have a Novatel Broadband Router with Voice in the house. I'm not sure they need Ethernet/Router at this location. Don't they make cellular modems for home alarm panels these days? Don't residential alarm panels place a phone call?
      https://www.google.com/search?q=nova...jmchmA4sHQb8M:
        Maybe use an ATA, VoIP gateway!
        Sent from my Nexus 6P using Tapatalk
          They can't use an ATA, the house is quite aways from the needed location.
          I found this Verizon Home Phone Connect. I think that's what they need. I did find a couple of industrial devices you put a sim card in, but they were 500 bucks.
            Sounds like they had an old POTs vacation home monitor box which I used to have in the 80's or 90's which had a relay switch and temperature sensors on it .
            I think I kept it someplace here. Not sure if it was maybe a Heathkit?
            Here today using an old unlocked Ericsson W25 3G modem that provides a landline and internet backup.
            Been working fine now for the last few years and currently serves as a backup to my internet (it is a failover for the PFSense box).
            Picked it up for $25 used. Works fine with Voice, FAX, Data, et al. It was a standard mobility office / offshore marine device a few years back mostly internationally. These types of devices have been around for years. Here also have and utilize a small combo WAP / SMS portable LTE device and a dual sim mobile command center (disaster site communcations) device which work OK.
            [ATTACH]69407[/ATTACH]
            I do want to switch to a more modern LTE combo modem sometime or another.
            BTW if I telnet / ssh or serially connect to it I can send SSH messages with the device.
