Guys
Other than a reinstall... which I assume is a db delete and plugin reinstall, any ideas on the error below?
If I do the above install - wil lI have to reset ALL my blradar setup again?
Here is the log at starup...
Thanks in advance
David
02/05/2011 03:05:36 ~!~BLRadar start~!~Register Callback completed
02/05/2011 03:05:36 ~!~BLRadar start~!~BLRadar version is: 1.0.83.0
02/05/2011 03:05:36 ~!~Plug-In~!~Initializing Plug-in: BLRadar
02/05/2011 03:05:36 ~!~BLRadar start~!~Initializing BLRadar...
02/05/2011 03:05:36 ~!~BLRadar start~!~Loaded configuration successfully
02/05/2011 03:05:39 ~!~BLRadar start~!~Sensors and Active Zones have been loaded.
02/05/2011 03:05:40 ~!~BLRadar start~!~User Defined Motion Code has been loaded
02/05/2011 03:05:40 ~!~BLRadar Error~!~DatabaseFunctionsSingleton.GetADODBConnection(): Caught exception opening database connection: Unrecognized database format 'D:\Program Files\Homeseer 2\Data\BLRadar\BLRadar.mdb'.
02/05/2011 03:05:40 ~!~BLRadar Error~!~DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: Operation is not allowed when the object is closed.
02/05/2011 03:05:40 ~!~BLRadar Error~!~DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: D:\Program Files\Homeseer 2\Data\BLRadar\BLRadar.mdb
02/05/2011 03:05:40 ~!~BLRadar Error~!~DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: DELETE from tblSensorActivity WHERE txtDateTime < #4/22/2011 3:5:40#
02/05/2011 03:05:41 ~!~BLRadar Error~!~DatabaseFunctionsSingleton.CompactDatabase(): An error has occurred during compacting of the database: Unrecognized database format 'D:\Program Files\Homeseer 2\Data\BLRadar\BLRadar.mdb'.
02/05/2011 03:05:41 ~!~BLRadar Error~!~DatabaseFunctionsSingleton.CompactDatabase(): DatabasePathAndName: D:\Program Files\Homeseer 2\Data\BLRadar\BLRadar.mdb
02/05/2011 03:05:42 ~!~Media Player~!~Finished loading Playlists
02/05/2011 03:05:42 ~!~BLRadar start~!~BLRadar plugin has been initialized
Thanks in advance
David
